12-14-2009
well stump, if you are in warm waters then you are trying to keep warm air temps out. if you are in colr water then you are keeping cold air temps out. normally the water is a pretty good temp buffer, always either warmer or cooler than the air out side.
also it has to do with condensation which happens under the water line really easily, even with insulation. it is much easier to fight it above the water line. so basicly one reason is to avoid getting the insulation wet with condensation
