Old 12-14-2009
dbruce85's Avatar
Ticon 30
dbruce85 is on a distinguished road
Strainer
I will be relocating the head intake this spring.
It sits under the v berth taking up valuable storage area. In a 26 ft. boat you need to utilize all the space you can.
I have found great info on installing thru hulls and repairing the old thru hull hole, I plan to do it correctly and install a flanged assembly.
The only thing I have not found info on is the correct way to screw a bronze round strainer into the hull.
I currently have a round strainer over the thru hull and would like to do the same on the new installation.
Do the screws just go into the fiberglass or do I need to predrill and fill with an epoxy first.
Thanks,
David
Old 12-14-2009
mitiempo's Avatar
I wouldn't put a strainer in. The only strainers I have seen were on engine cooling water intakes and the most common advice is to eliminate those. The narrow slots are more prone to marine growth than an open through hull. If they get plugged you can't clean them from inside the boat. Without a strainer you can remove the hose from the head and run a smaller hose or a dowel through it to clear if there is not a strainer. They rarely get plugged though.
Brian
Old 12-15-2009
capttb is on a distinguished road
If you decide to forgo the exterior strainer you may want to consider installing a small mesh strainer on the intake, keeps the bigger chunks of seaweed etc. from going thru your head.
JABSCO PUMPGARD LOW PROFILE INLINE STRAINER 3/4" I Shop.Sailnet.com - sailing resources, shopping, sail, blogs
"Democracy is two wolves and a lamb deciding what to have for lunch, Liberty is a well armed lamb contesting the decision."
Old 12-15-2009
cutterorient is on a distinguished road
I also have no strainer on my head intake and it has yet to be any problem. this also keeps it simple which I always love - less stuff = reduced probability for something to fail. Cost free risk maintanence. Little bits of growth end up in the terlet, but thats no big whoops for me.
Old 12-15-2009
JohnRPollard's Avatar
Moderator
Neither would I, for the same reasons.
Sea water strainer Install mogul11 Gear & Maintenance 8 05-12-2009 09:39 AM
sea strainer location and plumbing? e31 Gear & Maintenance 2 10-01-2004 11:36 AM
boats with easy engine, seacock, sea strainer, etc access night_raver Boat Review and Purchase Forum 3 08-26-2004 10:11 AM
Perkins 4-108 Oil Sump Strainer ABullard Gear & Maintenance 1 04-20-2004 01:00 PM
Sea Water Strainer joub Gear & Maintenance 2 01-19-2003 07:05 AM
