Boats on hard ground so lets talk grounds - Page 2 - SailNet Community
post #11 of 13 Old 12-16-2009
mitiempo's Avatar
xsboats
Yes there should. Not only does ABYC call for an AC ground to the central ground on the engine block but it makes common sense. Invertors and chargers are a bridge between the AC and DC systems. If an AC item shorts or a case becomes energized the current has to have somewhere to go. All AC circuits should be GCFI protected. New ABYC regs call for ECLIs to be installed on all new boats (basically a "whole boat" GCFI. (E-11.11.1)
Brian
mitiempo is offline
post #12 of 13 Old 12-16-2009
ABYC, A-28; 28.4.1 says they all get connected together, then to shore ground.
Howard Keiper
Berkeley
thekeip is offline
post #13 of 13 Old 12-17-2009
patrickrea's Avatar
As thekeip says, the DC and AC grounds must be bonded together as per ABYC. I use a 100amp BlueSea busbar to connect the AC, DC and the safety grounds that lead to my rigging together. I highly recommend a GALVANIC ISOLATOR on the AC ground, between the shorepower inlet and breaker panel, to reduce stray current that may be running around the DC system or in the water. It will save your zincs.
Patrick Rea
1978 30' Hughes Northstar 1000
1964 20' Bertram Moppie
patrickrea is offline
Windward performance deseely General Discussion (sailing related) 21 04-01-2012 02:42 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 02:15 PM
