12-16-2009
Originally Posted by xsboats
This is right for shore power except that there is no ground on board. All grounds are wired to the panel and then connected to the ground on the dock. There should be no ground for the shore power hooked up to the engine block, keel bolts, dynaplate, or any other grounding point commonly used in the d.c. system.
You are making this conversation interesting, I have Don Casey's book, Sailboat Electrics Simplified, and he shows the ground hooked to the engine, also the wiring diagram for my boat shows one (although it is not there). The Engine is certainly grounded to the 12v DC system.
