12-16-2009
the pointy end is the bow
Originally Posted by degreeoff
Ok so far so good alot of good info. Thanks!
Now here I have 4 6v's and a small 12v for starting, what pieces do I need other than batteries?
ACR ? (Ummm I no not what this is) Switches? External reg? (another one or a replacement for what comes on the alt) where would I find these and about how many bones will they set me back? If I am missing anything let me know I want to do this once for the next 5-6 years when I will sell her and go bigger....;-)
Typically, your alternator should be hooked to your house bank. To charge your starting battery, some folks turn the battery switch to "both or all" to charge it up, but you run the risk of forgetting to switch back to your house bank and depeleting your start battery while on the hook. For that reason, other folks charge their start battery through an echocharger or some sort of a battery isolator that combines the two banks when there is a charge present, but otherwise keeps them separate.
If your alternator is internally regulated, it probably has a cheap regulator on it designed to charge starting batteries. One of the best upgrades I did to a previous boat was to install a 100 amp externally regulated alternator and a three stage regulator. Balmar is a popular choice for external regulators and they sell alternators too, but I think they are over priced.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
