Old 12-16-2009
Jasper Windvane is on a distinguished road
Winch Sizing .. Lewmar 40 = what ??
I am confused. If I need two Lewmar 40 st 2 speed winches?
What size are the other brands ??
Some brands list 14, 16, that sort of number.
Lewmar lists 40, 48 .. blah blah
How does the sailor compare.. what size is the same ??
Old 12-16-2009
Jeff_H's Avatar
Super Moderator
I haven't done this in a while but you should be able go onto Lemar's website and there they should list the various working loads and power ratios with and without handles for each of their winches. You can then go on the websites for other manufacturers and compare those numbers. '
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 12-16-2009
petmac is on a distinguished road
Here's some info :
www.bitwrangler.com/winches
Old 12-16-2009
blt2ski's Avatar
Last I looked, ALL the current manufactures a "40" labled winch equaled the other brands of the same numer, ie a 40-1 was the lowest ratio on that winch. A 2 sp would have say a 20-1 speed, reverse the rotation of the handle, and it would be 40-1, hence a "2speed 40"
Typically winches under 15 or there abouts are singles, 15-48 or there abouts usually have two speeds. larger they start coming in 2, 3 an 4 speeds. With the number being the lowest setting.
Some "40's" will not be a 40 if you use an 8" handle, it would be about aa 36-1, and the higher would not be a 20, but an 18-1.
As jeff says, look up the specs on the given brands website. But it is not quite like the days of Barlow and Barbarossa, where a 16 Barlow equaled a 40 barbarossa, which is now Harken. Not sure of Barlow is out of biz, or is now say "Lewmar".
marty
She drives me boat,
I drives me dinghy!
Old 12-16-2009
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
What is the boat and application for the winch? I replaced the primaries on my Cal 9.2, were Barient 25's (~40 to 1) with Barient 27's ST. ( 48 to 1) By using a 8" winch handle in light air they are about 40 to 1. The smaller circle means you can crank faster..... If you need the power in heavy air just use the 10" handles.. My choice was largely based on the exact same hole mounting pattern for a easy swap. I hate to have to drill holes in a boat.
Link to article:
Winch_upgrade
Cal 9.2 #19 SilverSwan
Old 12-16-2009
sck5 is on a distinguished road
Mauri pro sailing has a lot of selection guides for various kinds of hardware that I have used to figure out what is equivalent for various things - some of the guides are better than others but it is worth a look
check here
Sailboat Hardware Selection Guide
(I have no connection with them other than having bought various pieces of hardware in the past)
Servicing older lewmar winch zeilfanaat Gear & Maintenance 3 06-06-2011 02:58 PM
Seeking a used Lewmar 44 ST Winch captnorm Gear & Maintenance 7 07-12-2007 06:29 PM
It's Winch Servicing Time Tom Wood Gear and Maintenance Articles 0 10-17-2002 08:00 PM
It's Winch Servicing Time Tom Wood Her Sailnet Articles 0 10-17-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
