-   -   rust on keel (http://www.sailnet.com/forums/gear-maintenance/6059-rust-keel.html)
gregreinhard 01-19-2003 12:38 PM
rust on keel
The leading edge of my fixed keel shows some surface rust - no doubt the result of encountering oyster beds in the Chesapeake. Is there a chemical rust killer/inhibitor that works? After the rust is removed should I seal the leading edge with something before applying bottom paint? Any advice would be appreciated.
Jeff_H 01-20-2003 02:08 AM
rust on keel
To some extent this depends on the way your boat has been constructed. Assuming that you don''t have an encapsulated keel, the easiest way is to wirebrush the area and remove any loose rust and use something like Ospho or Naval jelly to consolidate the surface oxydation. They you have a couple choices. There are zinc rich epoxies that bond very well to iron. There are also primers such as zinc chromate that also bond very well. Or you can visit the WEST System site and look at thier method of dealing with rusting iron keels.
If you have an encapsulated keel your problem is far more complex and I don''t have the time to answer that one this morning.
