12-19-2009
Electric heaters are just about the largest cause of fires. For good reason. They are all typically sized to give you the maximum amount of heat a 15 amp receptacle can deliver continuously. That's about 1500 watts. That much power is excellent at finding every poor connection, in the heater, at the cord end, in the receptacle, in the next receptacle up the line, in junction box, in the circuit breaker. Unfortunately this isn't a short circuit that a circuit breaker can protect against. So a lot of your heat winds up being produced at the bad connection, and starting a fire there.
If you are using an electic heater you should get in the habit of feeling the cord, cord end, face of the receptacle, other receptacles the current passes through, the circuit breaker, your shore power connection on the boat, the one at the dock, looking for any signs of heating. This only takes a minute to do, and may very well save your life.
Gary H. Lucas
