Used Aries Wind Vane -- Should I go for it? - Page 2 - SailNet Community
post #11 of 18 Old 12-19-2009
Omatako's Avatar
I had an Aires on a boat several years ago and found it difficult to get the boat to hold a decent course downwind. Great on the wind but . . . maybe I was just not good at setting it.
Arthur C. Clarke
Omatako is offline
post #12 of 18 Old 12-19-2009 Thread Starter
1982 Skye 51
obelisk's Avatar
The downwind performance gripe seems to span most brands of wind vane.
As for vanes themselves, can the shape be tweaked with at all for performance in different conditions, or is the standard tall and narrow design generally the best? I was planning on using some marine ply (6mm) to make a couple new vanes--should I make one bigger and one smaller for light and heavy wind? Any particular dimensions for either?
"The notion of life implies a certain absoluteness of self-enjoyment." -Alfred North Whitehead
obelisk is offline
post #13 of 18 Old 12-19-2009
Omatako's Avatar
It was a long time ago but my recollection is that a 6mm blade is too heavy. The blade needs to be in balance with the counterweight so that the vane reacts to every windshift. I seems to recall that we used 4mm marine ply to achieve decent response from the Aries.
Arthur C. Clarke
Omatako is offline
post #14 of 18 Old 12-20-2009 Thread Starter
1982 Skye 51
obelisk's Avatar
omatako,
you're correct, after looking at the manual 4mm is what they suggest.
obelisk is offline
post #15 of 18 Old 02-01-2013
Re: Used Aries Wind Vane -- Should I go for it?
omatako,
Everything I see has Aries recommending 6mm marine ply for the paddle.
sneuman is offline
post #16 of 18 Old 02-02-2013
Bristol 45.5 - AiniA
The Monitor vane is made from corrugated polycarbonate - looks like corrugated cardboard but very strong and flexible. Seems like a better option than plywood.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is offline
post #17 of 18 Old 02-02-2013
MikeOReilly's Avatar
Another happy Aries owner here. Price seems good if it's in good shape.
We have a couple of different vane sizes which we use depending on wind. It does require at least 8 knots to steer reliably, which is probably why some people report problems on the downwind sail (lower apparent wind). It also takes a bit of time to learn the art, but really, it's not hard to use.
Why go fast, when you can go slow.
MikeOReilly is online now
post #18 of 18 Old 02-02-2013
gts1544
obelisk, I bank at Wells Fargo in the USA and an international wire transfer is $30 for any amount. How does that compare to Western Union for $1700?
gts1544 is offline
Wind Orientation Mark Matthews Learning to Sail Articles 0 03-06-2005 07:00 PM
Charging with Wind Power Kevin Jeffrey Cruising Articles 0 04-21-2003 08:00 PM
Understanding Apparent Wind Steve Colgate Learning to Sail Articles 0 11-10-2002 07:00 PM
Understanding Apparent Wind Steve Colgate Seamanship Articles 0 11-10-2002 07:00 PM
Understanding Apparent Wind Steve Colgate Racing Articles 0 11-10-2002 07:00 PM
