Old 12-18-2009
Drake76's Avatar
Drake76 is on a distinguished road
j24 ID --- What is this?
Under the floor in the v-berth, I located this wooden item. I appreciate it looks like something for the mast, however, it has seen better days.
As this is my first boat, and I have not seen the boat with the mast up, I can speculate that this has something to do with where the mast fits into the keel, flooring inside the cabin or decking above.
Can anyone throw me a bone as to what this piece is called and where I can buy another one?
Apologies for the first blurry picture. I am not much of a photographer, and apparently not much of a sailor either.
Thanks
Greg
Old 12-18-2009
Looks to me like a piece cut to fit the deck partners... where the mast goes through the deck, installed from inside with the 'flange' side down. It would take the place of wedges often used here to locate the mast within the partners.
If the narrower parts match the deck cutout that should be it.
1984 Fast/Nicholson 345
Old 12-18-2009
tommays's Avatar
Its the mast blocks as said
It will work BUT currently they move the mast as far back as it will go so i use the shape of the forward one and use a shim kit to hold it in place
North Sails One Design
The guide will give you a better idea about the setup
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 12-21-2009
14432's Avatar
14432 is on a distinguished road
There's a company called JCD Custom Race Parts that makes mast blocks out of high density polyethelene (HDPE). They're a little pricey but will last. As an alternative, it's pretty easy to make your own.
Old 12-23-2009
Jaywalker is on a distinguished road
Is it just me or does the flange (wider) side look weathered?
Old 12-23-2009
14432's Avatar
Jay - you're correct the flange side goes up - i.e. the blocks are inserted outside and the flange catches the deck surrounding the partners.
First Boat - J24 Drake76 Introduce Yourself 12 02-23-2010 07:35 PM
J24 Heeling dirtylittlesecret Learning to Sail 26 08-07-2006 05:24 PM
capsize screen J24 question websdf Racing 1 07-25-2002 05:39 PM
suggestions on motor size for j24? ctesluk Gear & Maintenance 3 02-18-2002 07:15 AM
J24 Good first boat??? Cap_Jdog Boat Review and Purchase Forum 8 08-27-2001 06:35 AM
