Basics of Seacocks, Thru-Hulls, Valves - Page 2 - SailNet Community
post #11 of 17 Old 12-20-2009
Maine Sail's Avatar
Jas,
A big part of the problem is the material used in that gate valve..
This is a quote directly from the USCG..
Originally Posted by USCG
The Coast Guard specifically advises against the use of PVC components in vital systems, especially in sea water intake systems and pressurized piping systems.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #12 of 17 Old 12-20-2009
1975 Newport 28
jaschrumpf's Avatar
I'm not arguing. This goes on the list of things to do in spring when I have her hauled for painting. There's another gate valve still on the boat that looks new, but it also looks like a Home Depot special. It'll go too.
I'm not especially surprised. You should have seen the wiring that I replaced last year...
S/V Free Spirit
Monrovia, MD
jaschrumpf is offline
post #13 of 17 Old 12-20-2009
Maine Sail's Avatar
Ouch and double ouch on the wiring..
I just hate to see anyone loose a boat over something so easily preventable. I have personally had a PVC elbow, that was used by a big name builder back in the 80's, crack in my hand as I attempted to remove it. Fortunately this boat was on the hard at the time. I have a friend who had one threaded onto a bronze thru-hull by a PO and the PVC valve split at the threads due to differing expansion and contraction issues. His boat was in the water at the time and the leaking prompted him to rmove and replace it....
______
post #14 of 17 Old 03-15-2016
Does anyone have the size and number of thru hulls on a 1981 C30?
lpbosch is offline
post #15 of 17 Old 03-16-2016
Señor Member
ottos's Avatar
Re: Basics of Seacocks, Thru-Hulls, Valves
I take it you mean Catalina 30?
If so, try to call them at this link.
ottos is offline
post #16 of 17 Old 03-16-2016
Thank you Ottos. I did just that yesterday and got the answer I was looking for. Again, thank you for your help.
lpbosch is offline
post #17 of 17 Old 03-16-2016
Old enough to know better
Keep in mind you are talking about a 35 year old boat, so what was there on day one, hopefully is not what is there now. Undoubtedly there have been changes, so it is good to physically check! People often add and remove thru-hulls over the years, depending on use and equipment needs.
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
Seacocks - Who Needs 'em? SeaStrutter Gear & Maintenance 20 02-20-2007 02:43 PM
Through hulls drynoc Gear & Maintenance 5 08-14-2006 01:47 PM
Plastic Through-Hull Valves and Valve Flanges John Kretschmer Gear and Maintenance Articles 0 05-27-2001 08:00 PM
Closing Seacocks Tom Wood Gear and Maintenance Articles 0 12-20-2000 07:00 PM
Cored Hulls Jon Shattuck Gear and Maintenance Articles 0 10-03-2000 08:00 PM
