Old 12-19-2009
VIC26 is on a distinguished road
Repower options
I have a boat (26') originally fitted with an OMC saildrive which was removed and hung with an outboard that was sold by the previous owner. Is a saildrive necessary or can it be refitted with a shaft and more conventional set up. Just don't want an outboard hanging out there. I'm not sure what structural considerations I need to consider. Just a novice so let's not get crazy with details, Thanks
Old 12-19-2009
JimsCAL's Avatar
JimsCAL is on a distinguished road
Fitting a standard inboard installation into a 26 ft boat is going to be major undertaking. Engine beds, stuffing box, strut bearing, etc. Cost is going to be over $10k, even if you do a lot of the work yourself. I would stick with the outboard.
Old 12-19-2009
Jim's right... starting over with a conventional shaft/strut installation is a huge undertaking.
I completely understand your desire to get rid of the outboard hanging off the back, but it's very likely that the costs involved here will far outweigh the value of the boat, even after the repower.
Another tack to take may be to find a good used diesel saildrive and retrofit that into the existing hole.
1984 Fast/Nicholson 345
Old 12-19-2009
Thanks for the input. I must admit that I was really thinking about electric but I currently don't have a prop shaft to transfer the power to. I'm just a l lake sailer and this topic tends to turn into a pissing match between experts that offers very little info unless your trying to reinvent the wheel. For what it's worth this boat came equiped with a conventional diesel as well as the OMC in the same space (Victoria 26,only a few made).
Old 12-19-2009
Originally Posted by VIC26 View Post
Thanks for the input. ....For what it's worth this boat came equiped with a conventional diesel as well as the OMC in the same space (Victoria 26,only a few made).
By this I assume you mean there were two options, right? not both?
Not familiar with this design, is it a Morris boat?
Old 12-19-2009
This is a larger version of the Mcvay designed Victoria 18. Yes it was produced with either, not both. There were only 25 +/- made. Mine had an OMC. Others had a BMW (?) with a prop shaft. Not a lot of info on the 26 but there is a review on this site under V. I was lookin gat an 18 and ran across this one.
Old 01-07-2010
plethora68 is on a distinguished road
repower issues
It sounds like you want to set up an inboard solution. Has anyone thought of using a liquid cooled Briggs and Stratton Vanguard engine gear reduced to prop shaft? I cannot imagine that it would cost anything like 10K. We are talking about some fiberglass, and a stuffing box and a good belt drive set-up to create a reverse. The engine could be set-up with a fan and radiator so that it could be on a closed circuit. Also, this would be at least 100 pounds lighter than a Beta or a Universal.
Just an idea
Old 01-07-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
Prepare to get your feelings hurt.
Anybody who says " Just a novice so let's not get crazy with details" should not consider a repower, because it is ALL details. persnickety stuff like shaft angles, stringer installations, alignment. If you want to keep it simple, find a good used saildrive and install it where the saildrive was originally.
Saildrives are a much-maligned but perfectly usable propulsion system. They have their idiosyncracies, but from a lowest-cost, fewest- details standpoint, it is the only solution.
oh, and if you are going to pay someone to do it, buy another boat. It will be cheaper . So do it yourself. it isn't rocket science, and we are always here to help if you get into trouble.
electric? puh- lease.
Old 01-08-2010
tommays's Avatar
Just an idea
Well you would have some issues with everything electric on the motor NOT being ingition protected
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 01-09-2010
Mechsmith
Mechsmith is on a distinguished road
Just search " Saildrive". There are a lot of options there.
I use an eight hp Yamaha outboard with elec. start, charging system, and power tilt, mounted on a lifting bracket. Never had much reason to change. 29' sailboat.
There are disadvantages with any power unit.
M 5424 diesel for repower or parts. jefframage Ericson 4 04-12-2010 05:53 PM
Considering the Cyclone Season Options Doreen Gounard Seamanship Articles 0 01-18-2001 07:00 PM
E-Mail Options Paul & Sheryl Shard Gear and Maintenance Articles 0 08-19-2000 08:00 PM
E-Mail Options Paul & Sheryl Shard Cruising Articles 0 08-19-2000 08:00 PM
E-Mail Options Paul & Sheryl Shard Her Sailnet Articles 0 08-19-2000 08:00 PM
