Old 12-21-2009
nauticalnut is on a distinguished road
GPS cockpit Mounting
Hello,
I am looking for some way to mount my Lowrance XOG to the mizzen mast of a 25 ft sailboat. I dont want to make the mount permanent so drilling is out of the question. dose anyone know of any mount that strap or latch around? Possibly mounting off a cleat or of some sort of heavy duty suction mount that I could mount on the bridgedeck and take home at the end of the day?
Thanks,
NN
Old 12-21-2009
wind_magic has a spectacular aura about wind_magic has a spectacular aura about wind_magic has a spectacular aura about
Originally Posted by nauticalnut View Post
Hello,
Thanks,
NN
Do you have any steel you could mount it to ? I have used rare earth magnets to mount things before, the big ones can hold so tight you need a crowbar to get them loose. In any case it seems like an easy mount to build from scratch, you could just drill holes in a piece of weld steel and then lash the weld steel to the mast. Wouldn't be pretty but it would work. You can get pieces of weld steel at Lowes.
What are you pretending not to know ?
Old 12-21-2009
pedcab's Avatar
pedcab is on a distinguished road
Are you familiar with the way Laser dinghy sailors attach their wind vanes to the mast? A system like that could work...
Regards!
Pedro
Portugal
Old 12-21-2009
CaptainForce's Avatar
I mounted our GPS on a short piece of PVC with flat end covers. The piece is weighted with a zip lock bag of gravel inside and has a diameter that just fits inside one of our drink holders. I don't have a concept of a 25' boat with a mizzen in front of the helm, but if a clamp mount on a "pole" would do; then, check out the mount accessories in a bicycle shop. I've seen some promising things there. I'd avoid the big magnet plan because of compass interference, 'take care and joy, Aythya crew
Old 12-22-2009
Hi all,
The boat is a Beachcomber 25, Cat ketch rig, Yanmar inboard. Really a unique boat.
I dont want to mount anything permanent nor any holes in the mast since I am partnering with the owner on it. However there is a cleat for the mizzen halyard. I am thinking of getting a 1/2" nylon strap 18" or so long to go thru the cleat and around the mast. Then sew some heavy duty velcro onto it and put some velcro on the back of the XOG.
Old 12-22-2009
......The boat is a Beachcomber 25, Cat ketch rig, Yanmar inboard. Really a unique boat.......
Nauticalnut, I "googled" your boat & viewed some diagrams. I agree,- unique & innovative. Do you actually furl the sails by turning the masts?
The Cruising Cockpit Sue & Larry Gear and Maintenance Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Her Sailnet Articles 0 07-08-2003 08:00 PM
GPS Gets More Accuracy Jim Sexton Seamanship Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Gear and Maintenance Articles 0 05-21-2000 08:00 PM
GPS Gets More Accuracy Jim Sexton Cruising Articles 0 05-21-2000 08:00 PM
