Old 01-21-2003
sailorman10 is on a distinguished road
chain splicing
Ok, I have exhausted my search capabilities on the internet and realized I would have to turn to the real experts. I need to splice my 3 strand nylon rode onto a length of chain for the anchor. I have read that splicing onto only the last link of chain could would put more stress on the fibers due to the tight radius of the turn around the link and that a splice over the last several links is better/stronger. However, I cannot find any detail or instruction on making this type of splice. Does anyone out there know how to do this? I could cobble together a splice but would rather do it right since my boat will be riding on this splice. Any suggestions?
Randy
Old 01-21-2003
maestro is on a distinguished road
chain splicing
how about using a thimble and creating a permanent loop in the line. Then using a stainless shackle to connect the two together??
Old 01-21-2003
chain splicing
That is the setup I am using now. However, I am installing a deckpipe to store the rode below decks instead of in a canvas bag. The thimble setup will not pass thru the pipe.
Randy
Old 01-21-2003
ikent is on a distinguished road
chain splicing
The New England Ropes site has instructions for a rope to chain splice. Brion Toss''s Riggers Apprentice also shows another version.
Best of luck,
Ike
Old 01-21-2003
chain splicing
The splice on New England Ropes site is for an single link splice in the last link. I can do this splice with no problems however, What I am looking for is illustration or description of a splice into the last several links.
Randy
Old 01-21-2003
thefantasea is on a distinguished road
chain splicing
New England Rope has a "Contact Us" button on their website. It''s primary use is to request literature (including a splicing guide) but there is also a box for including comments. Why not pose the question to them?
Old 01-24-2003
chain splicing
After a little experimentation, I worked out the splicing process adequately enough. I wove the strands thru each link for about a foot and then turned and wove back thru the links to the chain end. Upon reaching the rope, I put in a long splice with about 7 tucks and finished off with the appropriate whipping. On my experimental piece, I tested it to failure with a 4 ton come-a-long between two trees. The splice held very well and the ulitmate failure was in the rope, not the splice. This type splice probably doesn''t make a stronger splice but it should reduce chafe as the load is spread out over several links instead of just one.
Randy
Old 01-25-2003
CaptGentry is on a distinguished road
chain splicing
If you are sending that splice into a deckpipe I would add a chaf guard to the splice. Some 2" heat shrink or some rawhide.
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 03:46 PM
splicing wire calamityjane Seamanship 11 09-13-2004 03:42 AM
How much anchor chain is enough? wmiii Gear & Maintenance 3 05-05-2003 04:12 AM
Chain rode/size & length southernman Living Aboard 5 03-06-2003 01:22 PM
Splicing Chain carisea General Discussion (sailing related) 3 08-21-2002 02:55 PM
