12-21-2009
"Fairhaven" Formosa 41
Originally Posted by mitiempo
The wire should be stranded - solid core is not smart on a boat. Wire nuts work best on solid core though. I doubt that a 15 amp breaker will work if both are on together as the water heater might draw most of 15 amps itself. I'd put them on separate breakers.
Thanks for the tips. I only use double jacketed, tinned, stranded wire for my 110 volt stuff ($$$). As for the breaker, I already have miles of wire running around and I don't expect the two devices will trip it. The 40amp battery charger would only draw 3A or so. A combination of lazyness (I hate running wire) and cost move me to try it with the 15A breaker first. If I find it is tripping, I'll replace the breaker with a 20A one.
Even though I've found a solution with the water resistant wire-nuts, it still leaves me wondering, how does the rest of the world wire up a standard 110v light switch. Do they use wire nuts for the white wires, or something else....
MedSailor
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
