01-22-2003
aluminium prep
I helped Peter Limmer , A Kiwi Yacht painter, fair and paint my hull, A 44 foot aluminum schooner. SO far it is the fairest hull I have encountered. We used 9031 awl product primer- basically there formulation of zinc cromate. The primer was applied over an 80 grit grind, within 2 hours of the grind, obviously small sections. The primer was coated with 2 coats of 545 high build a n awl grip product. the fairing was at first their polyurthane filler mixed on site with micro beads . Nearer the final fairing coats we used premixed filler. IT was hughly expensive, and took 3 months of almost every day. I could not know imagine the boat any other way ( the hull is dark purple, and awl grip color , and still fairer than any other I,ve seen
