Old 12-23-2009
obelisk's Avatar
1982 Skye 51
obelisk is on a distinguished road
Swapping out outhaul -- question about line diameter
I´m swapping out my outhaul and genny sheets and have run into a snag in measuring. My old outhaul is Sta-Set and I believed it to be 1/2" but when I compared it to my new mainsheet (1/2" Samson XLS) it is larger in diameter. The 1/2" Samson measures under 1/2" and the Sta-Set is right at 1/2". Both were under about the same load when measured.
How much is line diameter affected by load and would the effect be different between these two brands and models? I have not swapped out the outhaul yet--could it be 9/16" Sta-Set that measures 1/2" when under load?
"The notion of life implies a certain absoluteness of self-enjoyment." -Alfred North Whitehead
Old 12-23-2009
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
I think you're asking the wrong question. What load is on the outhaul for that boat?
To answer your question, tension on the line will effect the diameter a bit. It will very depending on cover/core material and braid.
Merit 25 # 764 "Audrey"
Old 12-23-2009
obelisk's Avatar
1982 Skye 51
There´s quite abit of load. I would like to push the size up as far as possible. The determining factor is the sheave size in the cheek blocks leading backto the cockpit.
More to the point--Could the line I have already be 9/16" Sta-Set if it measures 1/2" (with calipers) when under load? It is old and somewhat worn. The breaking strength of the 9/16" is more appealing but I don´t want to buy 80´of it and find that it chafes on the sheaves running up to the boom.
Old 12-23-2009
blt2ski's Avatar
Lets look at this a different way, Figure out the load, and find the line diam that will fit the sheaves without chafing.
There are a few of us that prefer to go to something stronger than Sta-set. I am one. I dumped ALL of my staset and went with Sampson's XLS Extra which gives me the ability to go with a 3/8" line, that is still stronger than the 1/2" line it replaced, with less stretch at the same load. Along with I do not have to worry about being at the larger diam end of the spectrum to have chafe going thru my sheaves.
Not sure if this is really what you want from an answer, but another way to look at it.
Also, while the XLS I used vs Sta-set is more $$ per foot, about double for the same diam, by being able to go to a smaller diam, the actual increase was more like about 40-50%.
Also, for my out haul, I use a 3/16" steel line rope equal. It is stronger than the 5/16" lines I use for halyards. BUT< being as I only need 25', $30 for the line is nothing compared to the lesser amount of chafe, along with less friction to deal with when adjusting the outhaul. which being as I race my boat, this is something I worry about. A cruiser that has a set it and go for the next two hours....may not worry about every .1-.3 knots with an out of adjustment line.....
PS on edit, if you go to Harken IIRC, or maybe PYACHT.com or sailnet.com store or, some other online sources, there are pages with in these sites that you can look your boat up, or go to a chart with sail area and will tell you the max load with different wind conditions. From here, you can then choose a line with the strength to fit your sheaves, and not stretch either, have better performance too.
Good luck.
Marty
She drives me boat,
I drives me dinghy!
Old 12-24-2009
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
For the outhaul, line diameter is only concerned over running through the blocks and hanging up internally. The tensile strength is a bigger concern. Dyneema, Vectran, PBO are stronger than polyester and can be downsized for the same tensile strength. I downsized to 1/4" inside the Cal 9.2 boom by using a super fiber double braid. Breaking strength over 4,000lbs. The only down side is that end termination , spliceing or knots becomes the weakest link and must be done with care.
For genny sheets, what feels good in the hands and works with the winches especially self tailers is most important. Some of the outside braids on the low stetch lines will not feel good in the hand.
Cal 9.2 #19 SilverSwan
Old 12-24-2009
obelisk's Avatar
1982 Skye 51
The major hang up is that I am in Buenos Aires right now and options are limited. There is a huge sailing community here, but mostly in the 30-35' range so too chandlery is sized accordingly. All Spectra, Dynema, etc. is too small for my selftailer on the outhaul (Barient 28).
I calculated the load on the outhaul with the (windspeed)*squared*X.004X(sail area in sq. feet) formula and came out to a number much less than I would have guessed. I used 25 kts for windspeed.
625x.004x651=1627.5lbs
This seems too low, but that's just a feeling. By that calculation, 1/2" would be fine. Realistically, that's my only choice down here anyway!
Getting Good Starts, Part Two Zack Leonard Racing Articles 0 01-15-2004 07:00 PM
Getting Good Starts, Part One Zack Leonard Racing Articles 0 12-18-2003 07:00 PM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
Off-Season Seminars, Part Two Dobbs Davis Racing Articles 0 01-09-2002 07:00 PM
