Old 12-24-2009
hooligan6a is on a distinguished road
Head pump not working
I have a Raritan PH2 head less then 2 years old and it takes 15 to 20 pumps to flush it. Sometimes it backs up. I replaced the joker valve, no help. Someway to clean out hose? acid?
Old 12-24-2009
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
Tank size, location, vent hose? need more information....
Cal 9.2 #19 SilverSwan
Old 12-24-2009
btrayfors will become famous soon enough btrayfors will become famous soon enough
The PH II is one of the most reliable heads aboard, providing you treat it well.
I'd start with some vinegar....pump it in enough so it's in all hoses and let it sit overnite. A couple of treatments might do the trick of helping clear any hose obstructions.
Also, could be your replaceable pump parts need replacing..not just the joker valve. Raritan makes a repair kit with the necessary parts for about $60-70.
Bill
Old 12-24-2009
JimsCAL's Avatar
JimsCAL is on a distinguished road
Time for a rebuild. The excessive pumping says the pump valves are gone.
Old 12-25-2009
GaryHLucas is on a distinguished road
All reciprocating pumps have two valves, an intake valve and a discharge valve. The joker valve is the discharge valve. The intake valve is the flapper valve at the bottom of the pump cylinder. The pump piston also has a seal around it. If that leaks by it also will not pump. If you look into the head while pumping you may get a hint of what has failed. If the intake flapper valve is failed you'll see water pushed back into the head on the down stroke. If the joker valve has failed you won't pull water out of the bowl, and the level will stay fairly constant. A failed piston seal would be indicated by it being real easy to stroke the pump, because it isn't rubbing against the cylinder. Hope that helps.
Devising a Better Bilge Pump Don Casey Seamanship Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 08:00 PM
Head Maintenance Blues Tom Wood Gear and Maintenance Articles 0 11-21-1999 07:00 PM
Head Maintenance Blues Tom Wood Her Sailnet Articles 0 11-21-1999 07:00 PM
