12-24-2009
I am far from being a professional, and I have managed with awl-grip. Do the roll, and tip method on the stern. The secret it to apply it thin with the roller, and then tip it gently with the brush. You can come back the next mkorning, and give it a second coat without sanding, and then a third, so, and so on. DO NOT try to apply a second coat the same day.
I have painted my cockpit, white stripe, and bridgedeck house with several coats, and only used a half gallon. I have put three coats on my hulls, and used less than a half gallon. I probably have 4 times the square footage you have to paint at least........i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
BORROWED, No single one of us is as smart as all of us! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
