04-23-2011
Originally Posted by hellosailor
Sorry to wake the dead...but I've seen comments that most of the moisture meters, including the Electrophysics, are actually capacitance meters. Oddly enough I have a capacitance meter, and a multimeter with a capacitance scale. Both read in microFarads, the standard measure of capacitance.
Which leaves me to wonder, does anyone know how the readings from some of these moisture meters actually translate into real capacitance (mF) and would it then be practical to just use the c.meter as a moisture meter, correlating say x mF as "dry, xx as "damp", xxx as soaked ?
Anyone have both types of meter, to make a comparison with?
You are correct that all pinless moisture meters actually measure capacitance. So a moisture meter will read high moisture levels where there are backing place, ribs, stringers.
I played around with the cheapo General Tools meter listed above, and with a $50 Ryobi, along with a borrowed CT33. None of them correlate with each other particularly well, and I think the reason is that they all have different "depth perception" based on their sensitivity. The GT meter was totally useless - readings were noisy and irreproducible. The Ryobi could be a useful tool for finding the source of water intrusion via gradients of moisture. But it does not correlate well with the CT33, which is sort of the "gold standard" that all surveyors use.
Electronic stud finders work on the same principle. I've used mine occasionally to track down moisture locations.
1998 Catalina 250WK "Take Five" (at Anchorage Marina, Essington, on the Delaware River)
1991 15' Trophy (Lake Wallenpaupack)
