12-25-2009
Tartan 27' owner
Originally Posted by moonie5961
In my aimless internet browsing, see several types of chain plates, and means of distributing the load of standing rigging.
My own interest stems from the fact that I want to replace my own-belonging to my 1974 Contest 31. All of my standing rigging is original, stainless and I'm sure riddled with crevice corrosion. To augment the problem of my own situation, mine are glassed in from below deck to prevent moisture penetration into the cabin. To me, this is asking for maintenance neglect, and an eventual disaster. Luckily, my decks have no core material to worry about, as they are solid glass.
Mine are like the stainless loopy ones on bottom, and they're what I will likely use to replace the current ones. Aside from being very expensive from the few places that I have seen them, what do you think of these?
Thanks, I look forward to hearing what you have to say.
Stainless steel will corrode in the presence of moisture and no air so glassing in any SS is basically a bad idea. I know this because the chain plates on my own boat were done that way back in 1967 and I have already replaced our aft chain plate. They built a knee wall consisting of a core of plywood which had the chain plate bolted to it and the whole thing was glassed over. Get a little water in the plywood and it turns to soil over time.
What some owners of the Tartan 27' have done is to rebuild the knee wall and put the chain plates outside the fiberglass so the bolts and plate can be inspected.
The 2 bottom photos look more like 'bow eyes' then chain plates to me. Usually your shrouds/stays will attach to the chain plate by using a clevis pin as in your first photo. Once you disencumber your chain plates from their fiberglass tomb you will likely see that they look more like the one in the attached pic.
