Old 12-26-2009
ADMTROX's Avatar
ADMTROX is on a distinguished road
Screen enclosure
I am going to make a screen enclosure for our sailboat. Does anyone have a reccomendation for the screen material? I need it to keep the little no see ums out but I need to be able to see clearly through it.
Old 12-26-2009
ekenna is on a distinguished road
We use 2 personal screens for camping. I think I got them at dicks sporting goods. They have 4 eyelets that you can attach over a person laying down. It provides a covering of 2 feet by 7 feet and then 2.5 feet. We just tie them over our forward hatch and our main hatch starting in the evening. I am sure you could use these to strech them over a frame.
Old 12-26-2009
WinterRiver's Avatar
WinterRiver is on a distinguished road
Consider the enclosure solution originally posted by Capn Ron:
Originally Posted by CapnRon47 View Post
Not sure this really counts as a project (other than the Admiral says it does). The creek and river we are on in NC has a major mosquito issue several times a year, so something is needed to keep them off if you want to enjoy the cockpit in the evening. I found a simple solution using a Walmart $30 screen siding that are sold for 10' x 10' canopy gazebo's.
I simply gathered up the the parts that attach to the gazebo frame with some line and I lay that over the bimini. The bottom has elastic straps that attach nicely to the bimini hold downs and it even has 2 zippered entries for easy access. Here is the Admiral enjoying the results of this 'project.'
I bought one last spring and it is a spectacular solution. While I am usually for diy, and know my way around a sewing machine, this works so well that I wouldn't consider making anything. It took about 5 minutes to install the first time, only because I had to tie a line around the top and swat at the mosquitos. The next time, with the line permanently attached, it was under two minutes. The zippered sides are great, but we typically just lift the side and slip under it. I like that the screening is not tight, so it moves when touched instead of ripping. It folds up easily and fits right back into the bag it came in, extra line and all.
Hylas 47
Old 12-27-2009
WanderingStar is on a distinguished road
Totally cool.
Sailing across the silver screen (Bradenton Herald) NewsReader News Feeds 0 07-02-2006 03:15 AM
capsize screen J24 question websdf Racing 1 07-25-2002 05:39 PM
C-22 Pop Top Enclosure lil roxie Gear & Maintenance 0 04-22-2002 04:07 PM
Choosing the Best Computer Screen Jim Sexton Seamanship Articles 0 11-14-1999 07:00 PM
Choosing the Best Computer Screen Jim Sexton Gear and Maintenance Articles 0 11-14-1999 07:00 PM
