12-30-2009
Looks like you have a main cover that doesn't wrap around the mast and gooseneck (already well worn?) so the 'rigger' did his/her best to just tie the sail AND the sailcover to the boom (can't tell if it's just a luff rope or slugged main, but I'm guessing it's just a luff rope). Unless it was just howling in the marina, or your second visit was a month or two after the first, this amount of chafe is as much the fault of simple neglect as much as the way it was tied. If you're in the water in the winter months, it's usually best to take the main off, especially if you're not checking the boat regularly. Your line 're-routing' is going to drive your neighbors nuts as the halyard slaps your mast. Just take it forward and clip it to your pulpit, pull it taught, and you'll be good to go. Take a walk around the marina and see how other boats are put away for ideas.
