Like Tree1Likes
Old 12-28-2009
mountforever's Avatar
Super Member
mountforever is on a distinguished road
I want to paint my main sail
How the hell do I do it? What kind of paint? I was just thinking of laying it out, taping it off, and using an airless hvlp gun to spray (lightly) the one color logo I want on my sail. Any specific types of paint or any suggestions?
Old 12-29-2009
Most logos and sail numbers on sails nowadays are stick-on. Not too expensive these days and bound to turn out/last much better....
1984 Fast/Nicholson 345
Old 12-29-2009
Izzy1414's Avatar
..........huh?..
Izzy1414 is on a distinguished road
Just vinyl lettering, Ron, or some different material?
S/V Boccata d'Aria
I'm not sure what Dickens are, but I think they may be important and I sure as hell don't want them scared out of me.......Izzy
Old 12-29-2009
Super Member
here's what i would like to do
Old 12-29-2009
nightowle's Avatar
nightowle is on a distinguished road
given that you have the art, it probably can be re-created as an applique on some sort....just do some web searching; particularly with banner and sign companies.
________
S/V Don't Panic!
O'Day 27
Seattle, WA
“Navigare necesse est, vivere non est necesse” To Sail is vital, to live is not.
Old 12-29-2009
We bought a used J105 main a while back and took the logo and sail numbers off, they looked like regular vinyl, maybe a bit thinner than the average decal.
Any vinyl sign store could make that logo easily, then make sure the sail is really clean before you stick it on. Sailmakers will carry the 'right' stuff, if in fact there's really a difference.
Old 12-29-2009
Jeff_H's Avatar
Super Moderator
The sail lofts use a sticki-back dacron material for logos that are CRC cut or else traced and cut with an exacto knife. The material in questions is called Insignia Cloth or is called Adhesive backed Insignia fabric. It is typically a light weight dacron that has been UV stabilized.
Here are a couple sources:
Insignia Cloth
Sail Numbers, Insignia and Logos
I would not try to paint a sail but if I were going to dye it, i would look for a waterproof silk screeneing paint, and silk screen it.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 12-29-2009
canadianseamonkey's Avatar
Caribbean Surveyor
canadianseamonkey is on a distinguished road
Don't use paint on your sail unless you want to ruin it. Like everybody else said, get it done professionaly.
Old 12-30-2009
ChicagoNewport27's Avatar
Purveyor of Fine Ideas
ChicagoNewport27 is on a distinguished road
Yes! Give it a try!
You can certainly paint your sails.
Sailrite recommends acrylic from Dick Blick or similar. Read this post:
ASP TALK
"Q: Hi guys, does anyone have experience painting logo's on dacron sails. What type of paints did you use or suggest and how did you apply the paints.
A:Any artists acrylic paint should work. I use Grumbacher's "Hyplar" (check my spelling). We will have 18 inch adhesive backed stencil material in the next catalog (and on the net very soon). It is available now -- use part #1013 -- it is $4.25 per yard."
Also, sailboats aren't the only places you'll find Dacron.
People who make ultralights, hang gliders, kayaks, and Radio-Controlled model airplanes cover their wood and metal frames in Dacron, in weights similar to what we use for our mainsails. They then paint them. (Check out this replica P51 Mustang built from wood, covered in Dacron, then painted to look authentic!)
Some recommend a good oil-based paint, while others have had luck with exterior grade latex.
Granted, RC model airplanes and hang gliders aren't exposed to the elements as much as your mainsail may be, and also, the Dacron used in a hang glider isn't furled at the end of the day. I'm not sure how well a painted main would stand up to being furled and stretched repeatedly, nor am I sure how well a painted main would hold up to being exposed to the elements for hours at a time for years on end. While your main won't be up 24/7, it will be exposed a great deal more than a RC model plane or hang glider would be. While the paint probably wouldn't hurt the fabric any, the paint itself would be tough to maintain an keep looking good. It could turn into a big eyesore of bleeding, fading, chipping, or peeling paint by year 3!
Google "painting Dacron" and you'll find a metric buttload of useful advice.... mostly on websites where people build hang gliders, ultralights, dacron-covered kayaks, and the like.
For example:
Ultraviolet Absorption of Latex Paints by Kirk Huizenga
UV barrier Latex Paint, using Latex paint as a UV barrier on aircraft, latex paints as UV barrier for ultralight aircraft fabric.
Re: Painting Dacron
Re: Painting Dacron
From "Latex Paint for Boats by Dave Carnell":
"Platt Monfort recommends for waterproofing the Dacron® skins of his Geodesic Airolite boats “...the simplest method being a good quality
exterior latex house paint.” "
Painting with Latex House Paint
One of our Fly Baby restorers is painting his aircraft with latex house paint.
He's been posting his progress to the Fly Baby mailing list, and is allowing me to repost his messages to my web page:
Painting with Latex House Paint - AviationBanter
A Pietenpol builder by the name of Kirk Huizenga did a series of
spectrometry tests on several colors of latex. Turns out that there's
nothing special about black, nothing at all. Paint it with whatever
color you want, they all protect from UV equally well. His report, the
transformed data and the analysis are available (pdf & xls files):
File Library Detail Kirk's Piet Files
Painting a Fly Baby with Latex House Paint
Painting a Fly Baby With Latex Paint - Fidoe
Hope any of that helps!
Best,
Ken
jameswilson29 likes this.
Last edited by ChicagoNewport27; 12-30-2009 at 04:38 AM. Reason: Forgot the P-51 Mustang image! Doh!
Old 12-30-2009
xsboats's Avatar
xsboats is on a distinguished road
One thing that old aircraft , replicas, and airolite watercraft have in common is that their cloth skins are stretched taut over a framework prior to painting and then stay that way. I would have to question whether the paint would crack on a surface that is repeatedly folded and creased.
Trimming Your Asymmetrical Spinnaker sandygoodall Seamanship Articles 14 03-31-2010 09:27 AM
Traveler question sohi07 Learning to Sail 11 10-21-2006 11:47 AM
What is the point of a traveller? dwbecker Learning to Sail 9 09-25-2006 08:35 PM
First Sail of the Season Bruce Caldwell Seamanship Articles 0 06-05-2003 08:00 PM
Testing Your Sail Trim Knowledge Brian Hancock Seamanship Articles 0 03-27-2003 07:00 PM
