12-29-2009
many won't like my answer because they hate 5200, thinking that it's difficult to remove or because they despise starboard plastic because nothing will stick to it. I have great success with starboard (I use black) that is bedded to my deck with 3M 5200.. Where I place a bolt through my balsa cored deck or any fastener, I first grind out the balsa and work with a fully epoxied deck mounting. I easily form my mounting pad from starboard, probably two layers in your 1&1/2 inch case, and place my hardware on top of the starboard. When I position the structure over the 5200 bedding compound I only lightly tighten the fasteners and let the compound cure for more than 24 hours so I'm not squeezing it all out with the initial application. I most often have an aluminum back up plate on the under side of the deck or large fender washers for each fastener. If I decide to remove this assembly in the future, I can always lift the starboard and slide a chisel under the 5200. If I've used the 5200 with a material that it adheres to more vigorously, I can always run a wire under the deck hardware,- I've even used dental floss with success.
Even my former teak hand rails and companionway tracks are now starboard plastic. 'take care and joy, Aythya crew
