where2buy non-standard teak handrails - Page 2 - SailNet Community
post #11 of 14 Old 02-05-2010
I replaced all the hand rails on my Hunter 27 back in 1983, and made matching ones inside too, to hide the through bolts. Carbide cutters for rounding them over cost quite a bit back then, but are cheap now. You can save a lot of teak if you make a pair by staggering them and interlocking them on the board. You just have to saw them out using a jig saw.
Gary H. Lucas
GaryHLucas is offline
post #12 of 14 Old 02-06-2010
That's the most frugal way of doing it, your typical 'stacked' method is easier, but wastes a LOT of material, and -needs- a much wider board.
This way you can get great results with narrower material, which is often a lot cheaper.
Ken.
merc2dogs is offline
post #13 of 14 Old 02-08-2010 Thread Starter
Panhandle Sailor
dreuge's Avatar
Originally Posted by smillinjack View Post
Don's Marine Salvage in Clearwater Florida. 727-576-8575 I have went down to them to get a few things. It's all old junk but you may luck out. I bought some port windows for My Starwin 22 in new condition and also some teak to make my hatch rail. Good Luck and good sailing.
Hi,
I was at Don's this Saturday for a transmission cable. I also looked in their teak trailer for hand rails. There were a few one and two loop rails, but nothing larger. They have plenty of teak scrap boards & odds-n-ends which one could use for projects (got me thinking about making a Dorade box).
dreuge is offline
post #14 of 14 Old 02-10-2010
Found a cheaper source of replacement teak rails
Home Page - Custom Teak Marine Woodwork
sells the replacement 75 inch long 12 inch on center rails for $104 each plus $26 for shipping to maine. So total was $234 for the set
The owner Dave Shuler seemed pretty decent and the shop is in Fla.
All the best
Andy
cruisingmom is offline
Getting a Grip Don Casey Gear and Maintenance Articles 0 04-11-2004 08:00 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Reducing Exterior Maintenance Sue & Larry Gear and Maintenance Articles 0 10-15-2003 08:00 PM
Homemade Teak Decks SailNet Gear and Maintenance Articles 0 08-01-2002 08:00 PM
Bristol Teak Tom Wood Gear and Maintenance Articles 0 11-02-1999 07:00 PM
