01-02-2010
Chastened
If you mean that you're having trouble actually finding the roller furling gear, I can point you in the general direction.
There are 2 kinds that might apply to you-
Jib or foresail furling, in which case you'll see a round drum at the bottom of the forestay, at the tip of the bow. You spin the drum to wrap the jib around the forestay which may have a flat, fiberglass or plastic bar that runs most of the way up towards the main mast.
Main sail roller furling- Some boats have a motor or hand crank that either wraps the mainsail around the boom or around a shaft recessed inside the boom so that the mainsail gets sucked down inside the boom. Look on the end of the boom or the front of the main mast to see if there's a place to connect a crank handle.
Hope that helps.
