01-02-2010
Originally Posted by SVPrairieRose
Thanks for the compliments and advice guys, but no-one can agree. I don't have an adjustable back stay, I don't want to have running back stays. I have to believe we are are pretty smart people here, will two riggers even agree on the answer? Is there only one answer?
My problem with your setup is that your headstay will limit movement of your masthead, and therefore limiting the effect the jumpers might otherwise have on your inner forestay tension.. and in any event you're not adjusting your backstay anyway...
That would leave the jumpers' job then, to stiffening the upper panel above the spreaders and presumably stabilizing the inner forestay attachment point.. not exactly tensioning, but....
You need a professional opinion on whether or not you can remove them as is.
Edit: maybe they can be downsized or repositioned in a way that interferes less with your foresails.
1984 Fast/Nicholson 345
