Old 01-02-2010
RichP is on a distinguished road
Best way to fill these large openings.
Well,
I've decided to bite the bullet with regards to the white areas on my boat and paint them, this means that I can fill some of the holes that the previous owner had cut (not very accurately) for various purposes.
This first hole had some perspex screwed onto in order to provide light for the quarter berth, there is another one on the opposite side of the cockpit that's just far enough from symmetry with this one that you notice it. :P
This second hole was cut at the front of the cockpit for a bilge pump, a silly place to put it IMO and I want to fill it as well.
As you can see the thickness of laminate for the cockpit is very thin (6mm), structurally this isn't an issue I intend to but in some reinforcing beams below, however I'm at a loss for the best technique to fill the cut outs which are far far bigger than the laminate thickness.
(N.B. West system epoxy is my preferred material of choice for this job)
Any advice much appreciated.
Thanks
Rich
Hi, i'm restoring my old quarter tonner on a budget! Read my blog if your interested!
Old 01-02-2010
xsboats's Avatar
xsboats is on a distinguished road
I would laminate a panel out of fiberglass on a piece of waxed paper on a workbench. Then cut it to fit the opening and glass it in place.
Old 01-02-2010
MATHURIN is on a distinguished road
You may look at Tim's projects, I learned a lot by looking at the pics he posts, and he frequently closes ports or various openings....
here:
Northern Yacht Restoration | Tim Lackey:* One Man, One Boat at a Time
n.b. I have no interests in NYR
Old 01-02-2010
pegasus1457's Avatar
Arf!
pegasus1457 is on a distinguished road
another suggestion
I would laminate a panel on the workbench as suggested, then cut it to size to just fit the hole, then laminate it to a slightly larger piece, insert the assemble from behind, epoxy it in place from the rear, then fill the remaining cracks and gelcoat from the front...
Fluctuat nec mergitur
Old 01-03-2010
Thanks people,
I was just after some additional oppinions because there's not much thickness of material to bond to, but the structural integrity of my cockpit is fairly important!
Old 01-03-2010
WanderingStar is on a distinguished road
Double it up, use a bigger backing. I would glass both sides of a piece of pywood for the parts.
Old 01-03-2010
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
If you do not want to grind, glass and paint, You could fab a Starboad panel to fit. I used 1/2 starboard to fab a new engine panel assembly for the cockpit, counter sunk the edges so it would only stick out 1/4".
I checked out your blog, a labour of love... I've restored a Santana525 which linda looks like the 1/4 tonne.
Cal 9.2 #19 SilverSwan
Old 01-03-2010
Thanks for taking the time to read my blog!
Its tempting to put the engine panel there, although I wouldn't let it stick out at all, I've seen to many snapped keys for that, especially since I have a very small cockpit so its cramped anyway.
I think I've got how I'm going to do it sorted!
Cheers
Old 01-04-2010
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
Put a layer of glass across the back; then build up from the front. When you are close to being up to the gelcoat level you can clean up any epoxy that is above the surface of the existing gelcoat; then gelcoat the epoxied-in section. The edges should be beveled back an inch or more so you will have adequate bond strength to the existing fiberglass. Use an angle grinder to bevel the edges before you start with the fiberglass/epoxy.
34 to large to singlehand? snider General Discussion (sailing related) 10 06-27-2006 10:56 AM
deck water fill caps endeavour yachts r1mannion SailNet Website Technical Support 1 05-25-2006 11:39 PM
'68 M34 Water Tank Fill Hose Question dancrosswis Morgan 0 04-01-2006 02:07 PM
Encounters of the Large Kind Randy Harman Seamanship Articles 0 01-12-2004 07:00 PM
large main or large headsail? jbarros Boat Review and Purchase Forum 2 09-29-2003 06:13 PM
