01-03-2010
Chastened
As others have said, if you're charged then the battery electrolyte won't freeze and burst the casing. As the batteries discharge, the chemistry turns from more acidic to more like water, and hence more prone to freezing.
As the temperatures drop, the batteries lose capacity. That's what the "CA" and "CCA" ratings are on the battery- one is cranking amps at 32F and the other I think, is at 0F. I forget the actual temperatures.
Anyway, the only reason to heat your batteries is if you are planning on using them- for starting or running some kind of light, or pump. I don't think a 100 watt lightbulb would be useless in an enclosed space if you were planning on placing a load on the batteries.
