Folding vs Feathering Prop - views requested - Page 3 - SailNet Community
post #21 of 59 Old 01-08-2010
Cal 9.2 SilverSwan
roline's Avatar
folding martec prop
I've had the Martec 14Dx12P on a 30ft Cal 9.2 since purchased. The only complaint with folding props is a weak reverse. Fuel consumption is good and I included a RPM to hull speed graph.
Cal 9.2 #19 SilverSwan
roline is offline
post #22 of 59 Old 01-09-2010 Thread Starter
Sailor & Member
dantaden's Avatar
Thanks again everyone for your comments.
I have read on other threads that most featuring props require periodical maintenance, Variprop, Maxprop etc.. I have also heard the same with Autoprop, but requireing annual maintenance (bearing replacement) and overhaul. Some owners had experienced losing Autoprop blades.
and other owners have experienced no or very little problems or maintenance with their feathering or Autoprop.
I suspect these are extreme cases and/or perhaps some impact from salt water.
Is the above a valid concern - can anyone share further experiences ???
Dan, Celestial 48'
Toronto, sailing Lake Ontario & Thousand Islands
dantaden is offline
post #23 of 59 Old 01-09-2010
MC1
Dan - Your summary seems about right from the reading I've done as well. One other item I can add about the MaxProp . . .
The MaxProp on my boat was corroded because the zinc was allowed to be completely consumed. In addition, the prop was a little oversized for the boat and was not allowing the engine to reach its proper full RPM (this was observed in the survey when I purchased the boat). Adjusting the pitch was not sufficient to overcome the problem in my case. The prop was sent back to PYI for refurbishing, and they were able to reduce the prop diameter, polish it back to like-new condition, lube it, etc.. PYI was very knowledgeable about the use of their product in a wide range of circumstances, and was very customer focused. It was nice experiencing such competent and truly helpful support from the vendor.
Here are the before - after pic's . . .
MC1 is offline
post #24 of 59 Old 01-09-2010
Originally Posted by MC1 View Post
Dan - Your summary seems about right from the reading I've done as well. One other item I can add about the MaxProp . . . .
MC - can you expand on the annual maintenance required on the Max if you've had it long enough?
I have an opportunity for a pretty good deal on a used Max - so I'm curious as to what's involved on an on-going basis...
Faster is offline
post #25 of 59 Old 01-09-2010
MC1
Faster - From reading other threads, I believe annual maintenance may be required for the AutoProp. Regarding MaxProp maintenance, re-lubing is recommend every 2 years, as per the following from the PYI web site . . .
PROPELLER MAINTENANCE
The Max-prop needs to be degreased a minimum of once every two years. We recommend Lubraplate “130 AA” grease.
There are two holes in the spinner of the propeller to grease. Remove the set screw from the forward holes with a #3 metric Allen wrench and screw in the zerc tower, attach your grease gun and fill the propeller with grease until the grease starts to come out between the hub (1) and the spinner (7). Replace the set screw and remove the set screw from the more aft hole. Reinstall the zerc tower and attach your grease gun and fill the propeller with grease until the grease starts to come out between the blades and the spinners. Remove the zerc tower and reinsert the set screw into the propeller. Do not leave the zerc tower in the propeller.
• With each pump of the grease gun rotate the propeller from forward to reverse to allow the grease to work through the propeller.
• The numbers above are from Figure 2 at the beginning of this Max-prop Manual
• Make sure that you always keep the zinc anodes in good condition. They must be replaced at least once a year. The propeller must be protected by a lot of zinc, so also use a zinc on the shaft when possible. When replacing it make sure that you clean the contact point between the zinc and propeller. Use a wire brush or fine sandpaper to clean the aft of the end cap and the forward face of the zinc to give the zinc good contact with the propeller.
MC1 is offline
post #26 of 59 Old 01-09-2010
Thanks for that... had found it myself just this morning and have printed it. Seems straightforward enough.
I take it you've not done this yourself yet.
Faster is offline
post #27 of 59 Old 01-09-2010
MC1
Correct, I'll be doing it myself for the first time this coming spring. I'm wondering if the recommended grease (Lubraplate 130 AA) is available generally (e.g., at WM), since they make a point of stating not to use Teflon grease as it will wash out easily.
MC1 is offline
post #28 of 59 Old 01-09-2010
Let's hope so.. esp since one of the reasons for recommending it was lower cost!
Faster is offline
post #29 of 59 Old 01-09-2010
FlyinNOE's Avatar
I installed a Flexofold on my 40' Beneteau Oceanis 2 months ago. Since then we have sailed 300 miles with the new prop.
I ordered straight from the US distributor here:
Flexofold Low Drag Folding Sailboat Propellers for Racers and Cruisers
Beautiful prop (I had it on my desk for a few weeks at work before the install!).
Performance wise there is a .5 to .6 knot difference between it folded and not folded. If I am sailing VERY slowly and I slowly motor down to neutral I can trick the prop into “windmilling” like my fixed prop used to with the sails driving the boat. I can be sailing 2.5 knots in light wind and hear it turning (if I managed to motor down correctly). Once I go down and grab the prop shaft and slow it slightly you can hear the blades fold and the boat accelerates .5 to .6 knots. I have done this a few times to verify the results and to prove the difference to friends.
Motoring is more efficient (same hull speed with 300-400 RPM less engine speed) and backing is identical to my old fixed prop.
Customer service was excellent.
The anode covers the working parts and pieces thereby reducing the likely hood of the prop being fixed by marine life.
Hope this helps.
Brian-
FlyinNOE is offline
post #30 of 59 Old 01-10-2010
Valiente's Avatar
I too noticed such an improvement in sailing qualities with my Gori folder in terms of acceleration in a puff that I had to revise at what apparent wind speeds I would change my sails (I have hank ons).
Basically, I got the better part of a knot for "free" and while I haven't noticed much change in "top speeds" for a given sail area, set and similar apparent wind speed, I get there quicker and the whole motion of the boat is "sprightlier" if that makes sense.
I can't necessarily attribute this to the folder, but my hull speed is, in theory, 6.9 knots on a 26 foot LWL. My GPS in current-free water once recorded 7.3kn on a close reach on a day with 25 knots, a No. 3 and a single reef set. Last Sept. 28th, with 25-28 knots, a No. 3 and a full main set, we hit 8.9 knots SOG on a beam to broad reach. I've never surfed for so long in this boat, and while I can't credit having a folding prop, my gut says that taking that resistance out of the equation allowed us to get surfing sooner.
Can't sleep? Read my countdown to voyaging blog @
Valiente is offline
Folding vs. Feathering Prop? MJKahn Hunter 4 08-06-2007 09:54 AM
Hydralign Feathering Prop BELLATRIX1965 Gear & Maintenance 2 01-01-2007 09:25 PM
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 10:40 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Feathering and folding props FredSprigman Gear & Maintenance 3 09-08-2001 06:21 PM
