Old 01-10-2010
n0w0rries's Avatar
n0w0rries is on a distinguished road
Problem with Jabsco manual toilet
The previous owner said the toilet was replaced recently. It seemed to work ok for a while, but I did notice occasionally there would be a scum line in the toilet, even though it was left empty.
I noticed it got hard to flush. I can pump it full of water easily, but when I switch it to dry to pump it out, it doesn't do anything. I felt a lot of resistance on the down stroke, so I took the boat over and pumped it out, just to be safe. I tried again and was able to push through the resistance, and then it would pump freely (but still do nothing)... then at random it would get hard to pump again.
Any advice? Unless it's a cheap/easy repair, I'm thinking of replacing it after reading on here.
1991 Catalina 34 "Summerwine"
Old 01-10-2010
kwaltersmi's Avatar
Broad Reachin'
kwaltersmi is on a distinguished road
This is directly from the trouble shooting section of my Jabsco manual toilet owner's manual:
Bowl does not empty & difficult to push handle down:
1) Open outlet seacock
2) Fully shut Flush Control Lever
3) Check joker valve, discharge hose or outlet seacock for blockage
Bowl does not empty and difficult to pull handle up:
1) Remove pump and check for blockage
There's 4 or 5 other trouble shooting tips listed. Feel free to ask for more!
You can also check Jabsco's Marine Toilet Support Wizard found here: http://www.jabsco.com/support/wizards/question-wizard-waste1-style-pagepath-imagepath-itempage-id-.htm
Old 01-10-2010
n0w0rries's Avatar
Thanks! I didn't even to think to check their website. Was able to download and print out the manual. Hope it's something easy!
Old 01-10-2010
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Some people just replace these units rather then buy the service kit which costs about $50. This unit costs about $150 brand new.
http://www.defender.com/product.jsp?path=-1|51|806|315133|823306&id=1055779
I am not sure if that is the same model as yours. There is a larger bowl version which is about $200.
Old 01-17-2010
n0w0rries's Avatar
Well went down and took the pump apart. Wasn't able to check the bottom/joker valves because there's nasty water in the toilet and I haven't been able to clean it out. Any problem with trying a plunger? Would rather not have to use a cup to empty the head.
Working on the head really SUCKS.
Old 01-17-2010
GaryHLucas is on a distinguished road
I work on waste treatment plants, so a boat head is a day in the park. When I need to clean out something before I work on it I use a shop vac. However, I DON'T use it directly! I get a 5 gallon buckt and lid. Cut a hole in the lid a little smaller than the vacuum hose and poke the hose into the hole. Get another piece of hose and poke a second hole in the lid for that one too. Turn on the vac and use the second hose to suck out the head, and even the head hoses, depositing everything in the 5 gallon bucket. No mess at all!
Gary H. Lucas
Old 01-17-2010
If you're going to re-build the head... I would highly recommend you look at buying a Raritan PHII/PHC refit kit that basically replaces the head with a PHII or PHC system but re-uses your existing bowl, which saves you a considerable amount of money off the price of a Raritan PHII/PHC head. The Raritan PHII/PHC head is generally considered one of the best moderately priced marine heads, unlike the Jabsco units, which are generally considered the equivalent of what goes into them in normal usage.
SBO has the Raritan kits available.
Old 01-17-2010
pdqaltair's Avatar
pdqaltair is on a distinguished road
Don't use a plunger! Pulling back on the check valves is bad and it will not help.
Plungers mostly such, and marine heads are designed to resist that. Take the plunger OFF the boat.
It sounds like a blockage problem, most likely in one of the hoses and possibly in the tank vent. Unless the hoses are cleared, a new head won't help. It doesn't sound like a re-build, not if there is resistance.
The scum line problem is fairly normal, if the toilet is not flushed with enough fresh water and the joker valve seeps.
Get some gloves and keep them on the boat. It's just poop. Think babies and it's no big deal.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 01-17-2010
Don Radcliffe
donradclife is on a distinguished road
Its been a while since I had the problem, but if you are able to pump wet easily and the dry is intermitantly hard, my guess is you need to look at (2) on the Jabsco list-the Flush Control Lever is not doing its job. Exercise the lever between wet and dry positions and see if you can get it to go further over to the dry side. You can also try holding it over to the dry position while you pump.
If pushing the lever further over doesn't help, the problem is internal to the pump. The good news is that the part you need to fix is at the clean top end of the pump. The bad news is that my experience with getting the top of the pump back together without leaks is not good.
Old 01-17-2010
pdqaltair's Avatar
Good points. It may also be mis-assymbled
Mine was, when I got it, and the problem was similar. Take a long look at the exploded view.
I've never had leak issues on the top and have taken it apart several times. Minor differences, I guess.
Problem with pump for manual head voodooacrobat Gear & Maintenance 6 07-06-2006 04:24 PM
Universal diesel engine problem bcolton Gear & Maintenance 0 04-26-2006 01:50 PM
The Foolproof Head James Baldwin Gear and Maintenance Articles 0 10-25-2004 08:00 PM
The Great Windlass Debate SailNet Seamanship Articles 0 11-30-2001 07:00 PM
The Great Windlass Debate SailNet Gear and Maintenance Articles 0 11-30-2001 07:00 PM
