Just temporary, but it should hold - Page 4 - SailNet Community
post #31 of 36 Old 01-11-2010
Originally Posted by midnightsailor View Post
I may as well chime in here too! It really dosen't matter if this was a roller furling boom or not, and with out seeing a picture of the forward end of the boom , it is impossible to telll from the end boom fitting itself. It could be roller furling or not. Regardless, what needs to be done is to fix this thing before bad things happen!! . As usual, there is more than one way to do this. I think , rather than boom bales, I would remove the end fitting from the end of the boom, It looks like it might be held on by self tapping screws, but if not there may be some rivets. Once the fitting is off, you can then remove the broken rotating part. It is probably held on be some type of locking nut, washer, perhaps a cotter pin too. AT any rate, in order to remove that broken rotating part the fitting has to come off because that stainless hex head bolt is not going to just unscrew from the outside! Once off, you can fabricate a new piece from some stainless strap or flat stock. Make it about the same length as the old part. drill three holes in it one at each end and one in the middle or better yet probably a little off center so that it will hang with the longer "half" down. Bolt this back on(might need some washers or spacer between strap and back of cap(end boom fitting) ....or not.. .... Now you can connect your mainsheet ( or if you prefer, boomstay ) to the lower hole in the tang(or strap, or whatever you want to call it) and the topping lift to the upper hole. Now you can remove the outhaul from that "nubb" or whatever you wanna call it , and connect it to the eye( or hole or ring..what ever...) Since I can't see how your outhaul is set up , I can't say for sure if that is how it was originally set up or not, but my guess is, is that it was.
Well said.
knothead is offline
post #32 of 36 Old 01-12-2010
mitiempo's Avatar
He might have some trouble removing the boom end fitting I think. Probably a bit corroded after 38 years.
Brian
mitiempo is offline
post #33 of 36 Old 01-12-2010
midnightsailor's Avatar
Yes, I concur. But it can be done. Us owners of these more mature boats learn to accept this and learn how to deal with it .It seems that after 38 years things either just fall off or are a challenge to get off, rarely an inbetween perhaps thats why I identify with them so much
midnightsailor is offline
post #34 of 36 Old 01-12-2010
A couple more like this and youll be a pro !
Danny33 is offline
post #35 of 36 Old 01-13-2010 Thread Starter
71Irwin32's Avatar
Sorry guys, the wifi at the CC marina has been down a lot, then they fixed it and it barely works at all......;
I do appreciate ALL the replies. Yes the front of the boom indicates it was a roller.
71Irwin32 is offline
post #36 of 36 Old 01-13-2010 Thread Starter
71Irwin32's Avatar
Yes, I also thing that fabricating and end strap to replace the broken piece is the best Idea, but I may use T6 (1/2 x 2 x 7 or 8") instead of stainless. I'll think about the shape for a bit, but flat strap may be fine....and easy.
The end cap is screwed on to the boom around the perimeter.....
M-18 - low RPM, Throttle hold John/Illinois Catalina 1 05-19-2006 11:17 PM
Stowing for Heavy Weather Sue & Larry Cruising Articles 0 06-21-2004 09:00 PM
Sail Repairs at Sea Brian Hancock Gear and Maintenance Articles 0 09-22-2003 09:00 PM
Hold That Line Tom Wood Gear and Maintenance Articles 0 10-03-2002 09:00 PM
Temporary Moorings Dan Dickison Gear and Maintenance Articles 0 07-21-2002 09:00 PM
