Mercury 8-hp Problems - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance
Old 01-11-2010
seb5thman is on a distinguished road
I hope this is the right forum for this question. I have a 2007 Mercury 4- stroke 8-hp outboard that gives me fits. It is connected to a 2.5 gal container with a bulb type primer. After priming the bulb the boat won't start half the time. I can smell gas so I think it's flooding, but it even does it on occasion when I only prime the bulb a couple of times. After waiting 15-minutes or so it will sometimes start, and if it does a lot of white smoke comes out. Other times I have to pull it 30+ times before it begins to sound like it wants to start.
The other problem is sometimes the starter handle seems to be seized up and won't allow me to pull start the engine. The engine is in neutral, and again it seems to have a mind of its own.
This is my first time with an outboard, so any suggestions would be helpful.
Reply With Quote Quick reply to this message Share with Facebook
  #2
Old 01-11-2010
tommays's Avatar
Tohastsu - 8hp 4cycle - tech questions
If you search this forum under Tohatsu (same as yours) you will get the low down on your problem which is generally form leaving fuel in the carb
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #3
Old 01-11-2010
75R20 is on a distinguished road
When it won't turn with the starter rope, you have most likely flooded a cylinder with fuel and temporary hydro-locked a cylinder. Next time it does it, pull the plugs and see if they are wet, and pull the starter rope while the plugs are out. It will probably turn over just fine. At the very least, pull the plugs and inspect them. They are probably junk from being flooded with fuel.
Good luck
Kary
SV Mariah
#49080
  #4
Old 01-12-2010
ChuckA's Avatar
ChuckA is on a distinguished road
The MarineEngine discussion board is the best place to get input on motors. Here is a link to their Mercury outboard forum. I've gotten a lot of great advice there.
Mercury Mariner Outboard Discussion Forum at MarineEngine.com
Best,
ChuckA
sailing a P28-1 Heart of Gold on Narragansett Bay
Twitter: @CoastalCafe_NE
  #5
Old 06-27-2013
charles b is on a distinguished road
Re: Mercury 8-hp Problems
sounds like the problem i had with my mecury 4 stroke 8 hp sameyear as mine i know what was wrong with mine but some one stole it off my boat they didnt cut the lock they cut the pice tha was locked to the lock didt take the gas tank mine was leaking gas you only need to prime it acouple of times then put it in the start position
  #6
Old 06-27-2013
Sal Paradise's Avatar
Captain Obvious
Sal Paradise is on a distinguished road
Sounds like flooding due to a worn out float needle on the carb. You are pushing too much gas in. Try starting without priming. I never have to use the primer bulb on mine.
Sal Paradise
Senior Researcher - Dunning Kruger
  #7
Old 06-27-2013
sounds like the same problem i had with mine same year make model horsepower someone stole mine i new what was wrong with it did you buy it new or used i baught mine new never had a problem with it untill 2010 then someone stole it off off my boat they cut the piece thati had it locked to then i had whitesmoke comming from mine to but thats because i ran seefoam through it the nit started to leak gas and the cylender was broken i was going to get it fixed but it was stolen i still have the gas tank for it and its a 3 gallon tank that came with the motor when i baught it
you dont need to prime it so many times that just floods the pump should only be one pull on the starting rope and make sure its in the start position white smoke how long has it been sitting becaue it will do that when its been sitting for a while also dont over fill it with oile that will wreck the motor
  #8
Old 06-29-2013
blutoyz's Avatar
blutoyz is on a distinguished road
Try one squeeze on the primer and full choke. I think you are flooding it with the primer. If it floods, open the throttle full and pull it with no choke, that will clear it out.
Just get to know the engine and you will be fine, it is finicky
You may post attachments
You may edit your posts
How to trouble shoot yacht problems with a laser temp gauge DIY yachtwork General Discussion (sailing related) 0 01-01-2010 12:07 AM
Mercury 2.5 Hp problems Goodwood Gear & Maintenance 2 09-14-2009 02:47 AM
Major Problems With Marina hamiam General Discussion (sailing related) 33 11-28-2007 04:33 PM
Mercury 5HP:Rabbit ears go where? jr438234606 Gear & Maintenance 5 05-12-2006 11:05 AM
Mercury 25 4-stroke dlschilke24 Gear & Maintenance 0 05-25-2004 06:31 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
