01-12-2010
baDumbumbum
Interesting topic -- update us as you find out details! Good gels can take more abuse than flooded batts: some up to 3000 cycles from full to 80% DoD (which is what qualifies as "Empty.") As long as you keep charging rates and voltages under control, they are amazingly resilient. AGMs exhibit similar deep-cycling performance, and they are a bit less touchy about recharging (tho still touchier than flooded). Dry cells accept and discharge amps faster than wet cells, but they don't like being overheated (esp. gels).
The batteries in this case aren't showing their best at a 3-hr discharge rate. But yeah, a digitally-controlled trolling motor can run two or three times as long as the older 5fwd/2rev models. I'm a wee bit unhappy with our MotorGuide VariMax 45 lb thruster, though. They dunk the circuit board in urethane to marinize it, but it overheats very quickly in hot weather (80F), cutting power to 25% to prevent overcurrent -- or stopping altogether. Naturally, this happens right when we're trying to pick up a dock or mooring in a crosswind. I have to pour lake water over the thing for ten minutes to get it working again. According to Motorguide, this isn't a defect -- it's a design feature.
Also, the hp equivalents of trollers are hard to figure precisely. (Especially given the rating nonsense on all sides.) Our 45lb thrust motor w/ 3-blade prop is probably a short 1hp. We top out at 3 knots and can't make way in a stiff headwind. How did the J24 go with the 85 lb thrust? We like the quietness, we like not having gasoline aboard, and our boat suffers from weight on the transom, so the troller is a nice choice for lake sailing. But they're marginal in the giddyup department. We'll be adding oarlocks this Spring.
Buccaneer18, Grainnia
SJ21, Diarmuid
