-   -   Gibsea 43' Rudder Rebuild/Replace Help (http://www.sailnet.com/forums/gear-maintenance/61250-gibsea-43-rudder-rebuild-replace-help.html)
jkemp 01-13-2010 12:56 AM
Hoping to find someone with knowledge/experience or possible contact with someone with any knowledge/experience about replacing/repairing the rudder on an old Gibsea.
Gisaacs 04-19-2010 10:25 PM
Rudder rebuild
I am rebuilding the rudder on my 1980 Gib'Sea 40. I pulled the rudder of last fall and cut out one side with a skil saw. The foam was completed degraded however almost everything else was in good shape even the wooden stringers that create the rudders form. Once everything was cleaned out, I epoxied the interior and poured epoxy into hard to reach crevices and let it harden. Tomorrow, I am filling the cavity with a two part liquid foam. Once the foam has hardened I will reinsert the cut out side panel and reform the exterior with a silica/epoxy mixture. Once faired I plan to cover the entire ruudder with another layer of fiberglass. Its not a difficuly job , just takes a little time.
grant64 11-01-2012 09:55 PM
Re: Gibsea 43' Rudder Rebuild/Replace Help
I have a rudder that is leaking water at the seam both on the bevelled leading edge and also on the blunt squared edge at back of rudder above the water line. I plan to glass them over and am okay with that. Not clear on what happens next once glass is shaped and hardened in place. Do I now need a gel coat covering or do I simply paint to match the rest of the rudder?
Also - I am comcerned about condition of core rudder. After reading about rudder repair I am concerned about condition of core and what happens if I don't cut it open to check it out. Could rudder fail?- I sail a 27' Tanzer. Does anyone know what the core is ( wood or foam).
SloopJonB 11-02-2012 02:18 AM
If it's leaking water, at a minimum I'd drill some holes in the bottom to ensure it's fully drained. If you don't want to cut it open, at least capture the water and check to see if it's rusty looking.
As for refinishing, plug the drill holes with thickened epoxy, coat it with glass and epoxy resin, thoroughly sealing all seams and then coat it with Interprotect and bottom paint. Gelcoat is not necessary.
grant64 11-02-2012 05:45 AM
Thanks JonB - will drill later today and check for rust.
glen
