01-13-2010
Most boats, especially ones that are going to be used for longer term cruising, are going to sit low on their lines to some degree. You may want to use a barrier coat, like Interprotect 2000E, as a primer, but it really depends on what bottom paint you're using. Some paints will stick to properly prepared gelcoat just fine, others need a primer.
