Old 01-14-2010
FrankET is on a distinguished road
Send a message via Skype™ to FrankET
Rudder repair
I discovered that my rudder was turning on the stock. I was wondering if anyone had any Ideas about how the stock is attached to the rudder. Some were I read that a tube was layed up in the rudder and the stock welded to it. Some one else suggested that the stock had bar welded to it and the rudder layed up around that. I don't think the stock goes much more than 6" into the rudder. Do you think it posable to remove the rudder with out pulling the shaft? Anybodies experience with this type of ruddr would be appreciated.
I guess I'm too new to this site to post a photo so I'll try to describe the rudder. It has a large cut-out for the prop. leaving about 6" above said cutout. the rudder attaches to the back bottom of the keel with a dudgeon. The hull has a moderate overhang so the stock goes through a built up section right below the water line.
Thanks for any help.
Old 01-14-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
What make and model is your boat? with that info, we can come up with some informed answers.
Old 01-14-2010
Oh sorry, the boat is a cheoy lee offshore 31
Old 01-14-2010
Old 01-14-2010
xsboats's Avatar
xsboats is on a distinguished road
The stock will be welded to metalwork that bends around the propellor aperature and the continues further down into the rudder. It will join back up with a lower shaft , which continues down to become the lower pintle. If your rudder shaft is rotating inside of the rudder freely, then the weld is either broken or corroded through.You will need to split the rudder in half to access the metalwork for repair or replacement. I usually use the existing rudder as a plug to fabricate rudder mold halves before the demo work. Most rudders I have rebuilt had significant water intrusion in the core and could not be reused, so I found it better to build the molds before destroying the shape of the rudder.
Old 01-14-2010
What do you use to make the plug? Is it posable to remove some rudder material, repair the weld and build the rudder back up?
Old 01-14-2010
CaptainForce's Avatar
Another option, as I once employed, would be to split the old rudder port & starboard; repair the weld & metal interior; and then build the new half upon the half you select to save. 'take care and joy, Aythya crew
Old 01-14-2010
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Here's how one person did it on a smaller boat.
Rudder Repair
Google rudder repair, and you can find similar examples.
Merit 25 # 764 "Audrey"
Old 01-14-2010
xsboats's Avatar
FrankET, I removed the bottom paint from the rudder, waxed it and pulled a port and starboard mold off of it. I then layed up cored glass half rudders in the waxed molds, hollowed them for the metalwork, epoxy puttied them together, and then glassed the seams. Oh yeah, there was also a lot of grinding and fairing in there too.
Old 01-15-2010
Thanks for the advice. It looks like I got my work cut out for me.
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 01:11 PM
Emergency Steering John Kretschmer Seamanship Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Cruising Articles 0 03-08-2002 07:00 PM
Rudder Problems Mark Matthews Gear and Maintenance Articles 0 02-13-2002 07:00 PM
