01-15-2010
Umm,
First things first!
What is the state of the plumbing on this boat? Seacocks, Hoses, etc... First priority is to make sure she won't sink!
Second, you can redo the likely rats-nest of wiring later, but you do wan't to make sure there are no faults in the wiring that could cause a fire.
Third, are you going to sail this boat? What is the condition of the rig and rigging?
The teak, chrome, and gelcoat can all wait -- they are essentially purely cosmetic. You'll want to inspect the fiberglass cracks to make sure that they're not structural -- to the extent that they are, you want to deal with them first. But while you are at it, do you have a cored deck, or a cored hull? If you have any soft spots, you'll want to do a re-core job before you do anything else in that area.
The condition of the non-skid is an important safety issue, and so you may want to deal with that once you're sure that the hull and deck are sound.
Good Luck!
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , a new voice for ocean conservation
