01-15-2010
Moderator
It's hard to make a good recommendation, not knowing the layout of your cockpit. Nobody likes cutting holes, but bulkhead mounts generally result in very clean installations, protected from damage. Ideally, you'd have two: One on either side of the companionway as far outboard as possible. This allows better visibility and viewing angle when hiking out.
I like Ritchie Compass. You can see their various offerigns here.
Plastimo, Suunto, Brunton, Danforth are other makers. Palstimo has a new bulkhead option sized for smaller boats.
Another option is to get a digital compass from someone like KVH or Tacktick, which would mount to the mast on a bracket under the boom gooseneck. Or even just get a handheld GPS with a fluxgate compass feature.
