Old 01-18-2010
Red
redhead78 is on a distinguished road
seacocks again
hey guys thanks for the info on the fiberglass blocks. I am confused as to the threads on the parts. I was going to use a groco tri flange 3/4'. I think it comes wf nps threads top and bottom. Valve should be nps also? The groco bronze thru hull is nps also correct? I'm confused...Red
Red, 77 Jeanneau Gin Fizz 38
Old 01-18-2010
Maine Sail's Avatar
try this
Red,
Try this..
Seacock & Thru-Hull Primer (LINK)
______
-Maine Sail / CS-36T
Old 01-18-2010
Red
seacocks
Ol mainesail, that helps, That is the groco tri flange I am going to use. It has a nps on the bottom side and the thru hull is male nps, apparently the top of the tri flange[male end], I can install an npt ball valve.Then the 3/4" hose barb is also npt. I like the idea of the tri flange, in case of valve failure. ....Red
Greasing Seacocks sachemgfp Gear & Maintenance 1 09-30-2009 10:18 PM
Flush Seacocks Aleutian Tern Racing 6 12-21-2008 05:35 AM
Seacocks - Who Needs 'em? SeaStrutter Gear & Maintenance 20 02-20-2007 02:43 PM
Rebuilding seacocks aphil138 Gear & Maintenance 1 01-04-2004 01:32 PM
Closing Seacocks Tom Wood Gear and Maintenance Articles 0 12-20-2000 07:00 PM
