Revere PFDs - Page 2 - SailNet Community
post #11 of 27 Old 01-19-2010
Two choices.... one is use a Canadian supplier, like Binnacle.ca or two, order them from a US Supplier and have them delivered to a US address and then bring them across the border as personal items.
Originally Posted by PaulinVictoria View Post
Yeah, I looked there smack, but I need Canadian approved versions, then shipping on top, plus taxes, import duty etc so it works out to be about the same, just more of a headache. If I were south of the border then it'd be a no-brainer.
sailingdog is offline
post #12 of 27 Old 01-19-2010
mitiempo's Avatar
If he does the latter they probably won't be approved in Canada. If he gets stopped in Canada they have to have the Canadian approval on them.
Brian
mitiempo is offline
post #13 of 27 Old 01-19-2010
Depends on the brand...
post #14 of 27 Old 01-19-2010
jackdale's Avatar
They must have the correct label:
The Canadian addendum includes the following requirements:
* devices must be marked as being approved by Transport Canada or, for previously approved PFDs, the Canadian Coast Guard;
* all markings must be in both official languages;
* a specific Canadian warning label must be affixed to all devices; and
* there are some amendments to, and clarification of, the technical requirements.
jackdale is offline
post #15 of 27 Old 01-19-2010
Some will have the canadian labeling on units sold in the US, others won't.
post #16 of 27 Old 01-19-2010
mitiempo's Avatar
In French?
Brian
mitiempo is offline
post #17 of 27 Old 01-19-2010
Ticon 30
dbruce85's Avatar
Inflatable life vests in Canada must be worn to be counted, (one life jacket per person rule).
So unless you have them on every time you leave the dock you still need regular life vests.
As long as you have a regular life vest for each person on the boat, you could still purchase and wear an inflatable when you wish, regardless of the US or CAN certs.
dbruce85 is offline
post #18 of 27 Old 01-19-2010
mitiempo's Avatar
As far as I can tell from a terrible website - Canada's safe boating site - inflatable PFDs are ok by themselves. This was apparently changed in 2007. I could find nothing about having to wear them but it is suggested. On the Revere site they list approvals and they are all USCG and Canada is not mentioned anywhere I could find. So you could certainly own and wear one but they apparently are not approved for Canada. You would still have to have a Canadian approved lifejacket or PFD for each person on board.
Brian
mitiempo is offline
post #19 of 27 Old 01-19-2010
This is also true of the USA...
post #20 of 27 Old 01-19-2010
jackdale's Avatar
Small Vessel Regulations (16.07)
Regulations Respecting Small Vessels
(2) Subject to subsection (3), a personal flotation device may be of an inflatable type if
(a) it is worn in any open boat; or
(b) it is worn by a person in any boat that is not open while the person is on deck or in the cockpit, or it is readily available to the person when the person is below deck.
(3) A personal flotation device that is fitted with an automatic inflator shall not be used by a person on a sailboard.
Revere models 61068, 61069, 61070, 61071 are Transport Canada approved. http://wwwapps2.tc.gc.ca/saf-sec-sur...n/APCI_PFD.asp
jackdale is offline
