fuel consumption gas vs diesel - Page 3 - SailNet Community
post #21 of 26 Old 05-10-2013
Question Re: fuel consumption gas vs diesel
[QUOTE=JohnRPollard;521105]An old thread, but what the heck...
Over the course of 8 seasons, our current 3 cylinder 27hp diesel has consistently burned about 1/3 gph during normal sailboat operations. We push it hard (2700-3000 rpm whenever we're motoring, except when docking and during warm-up/cool down).
Our previous 2 cylinder 18hp diesel burned about 1/4 gph during normal sailboat operations.
Hello, new to your forum...
By "normal sailing operations", did you mean your motor is running to assist your sails, or running alone, under full load???
Is your diesel motor really that efficient?
A dumbfounded gas user.
-Planning to build a fuel efficient trimaran for inter-island travel, Hawaii.
-Mahalos from Maui.
bubblerings is offline
post #22 of 26 Old 05-10-2013
Old enough to know better
[quote=bubblerings;1028438]
-Mahalos from Maui.
That sounds about normal for gph under power alone. What have you used that was gas powered? Remember sailboats are generally displacement hulls, so you are not talking about speed, likely 7 knots at most depending on length. I don't see inter island travel to be that patient, unless it is for tourists and is a stay aboard. Why spend a whole day when you can get a cheap flight for short money (especially with the kamaaina rates). Now if you are talking typical ferry speeds you will spend a lot more!
miatapaul is offline
post #23 of 26 Old 05-11-2013
Senior Smart Aleck
jameswilson29's Avatar
-Mahalos from Maui.
Yes, diesels are that efficient. My 3 cylinder 24 h.p. burns about half a gallon per hour running alone under full load:
jameswilson29 is offline
post #24 of 26 Old 05-11-2013
Wish I never found SN!
SimonV's Avatar
My Perkins 4.108 should burn about 2.5 l/h @2400 revs giving 6.5 knots. When trip planning, I use 3 l/h and a speed of 5 knots, and a max running time of 100 hrs. As I carry 420 litres, my workings should give me a decent safety net.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #25 of 26 Old 05-11-2013
My Yanmar 3GM30F burns 2 liters/hour at 2500RPM, pushing the boat at 5.5 to 6.5 knots, depending on sea state. Does that jibe with other owners of 3GM30F engines?
Vindö 50
copacabana is offline
post #26 of 26 Old 05-11-2013
Thank you, everyone!
I will have to seriously consider a small diesel, now... I had no idea!!!
And, yes I will eventually be sailing, one day.
Up until now, my life revolved around being IN the water... freediving.
I do love ON the ocean, as well... maybe I just won't have a car!
I need a boat more than wheels.
Diesel fuel RSchneider Gear & Maintenance 4 10-19-2009 09:39 AM
Diesel fuel filters ahoyjim General Discussion (sailing related) 0 01-06-2006 06:47 PM
Fuel Return Ratio pma_foyl Gear & Maintenance 8 07-22-2004 01:22 AM
is diesel fuel compatible with lined tank? johnbonner31 Gear & Maintenance 1 12-27-2002 02:10 AM
old diesel fuel capedoryus Gear & Maintenance 1 12-17-2002 07:14 AM
