01-20-2010
How much time or money do you have?
Hey,
You can try the heat / soak / try / repeat method. Or you can give up and take out a saw. What condition is your prop shaft? If you suspect it is worn, then just get a good sawsall and start cutting. Cut the shaft. remove the 4 coupler bolts, and be done with it.
On the other hand, if you are short of funds and are fairly certain that the prop shaft is perfect, you can keep on trying to remove those bolts. Once you round the head your best bet will be a large vice grips and a mallet. Heat and oil will help.
Good luck,
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
