01-20-2010
Mechsmith
In my Seafarer 29 KCB the pin was installed in place and the hull was laid up around it.
The swing portion of the keel has a slot that hooks over the pin. Kind of like a thick plastic coat hanger. A strap keeps it from falling off if the cable breaks.
You should be able to see the pin by removing the strap. If not remove the swing keel.
