Old 01-20-2010
seafrontiersman is on a distinguished road
Marking a centerboard cable
I have a stainless steel cable to raise and lower my centerboard, it works great but I want to mark the cable so I know when it is completely raised. I've tried tape, paint, and a plain whipping and they've all been rubbed off .
My idea is to mark it with "gun blue" which is used to permanatly stain metal but I'd like to have a brighter color. Anybody got a better idea?
Thanks in advance!
Mike
Old 01-20-2010
knothead's Avatar
Instead of a plain whipping, you might try to pass your thread under some of the strands. The wire is 7x19 so it should be flexible enough to do that.
I bet that a bright colored ribbon passed through the wire a couple of times would last for a while.
Ron Paul 2012
"wikijar"
Old 01-21-2010
Thanks for the tip about the ribbon, that seems like a great idea and I'll give it a try!
Best of everything to you.
Old 01-21-2010
I wouldn't recommend using ribbon or a whipping, as both of these will tend to hold moisture against the stainless steel and promote crevice corrosion. Coloring it with some sort of metal marking dye would be a better idea IMHO.
Old 01-21-2010
knothead's Avatar
Good point SD.
seafrontiersman, I was remiss in pointing out that you should keep your centerboard cable lubed.
Including the brightly colored ribbon. Having an un-oiled ribbon will definitely shorten the life of the cable by a day or two.
Ron Paul 2012
"wikijar"
Old 01-31-2010
I used a strand pulled from the cover of an old sheet rope I had laying around and pulled it through the wire using a big sail needle and it works GREAT!
You're a floatin' Mc Guiver!
Thanks!
Mike
centerboard cable reinstall ambianceack Gear & Maintenance 8 10-11-2006 05:40 PM
advice on reinstalling a centerboard cable ambianceack Sabre 0 09-20-2006 10:04 PM
Pearson 35 Centerboard Cable lazypointer Gear & Maintenance 0 12-04-2000 06:37 PM
