01-21-2010
"IF" you can get someone to do the splice, or obviously do the splice yourself, then I would go for it. Reality being, even if this splice is 50% of the rope strength lets say, you will not have much pressure, other than an initial pull of 4-6 up the mast before you are pulling on non splice line. This might also be a good time to use a different color for the end, to initial color code the different halyards.
BUT, some place will not work with older lines/ropes, as they become hard, and do not splice etc well. While the lines may look good, for a rigger type, they may not be worth the effort!
Marty
She drives me boat,
I drives me dinghy!
