Old 01-24-2010
Petar is on a distinguished road
Has anyone made a plug on ..
their diesel engine crankcase and use it to change oil instead of messing around with pumps and hoses through dipstick hole which is messy and inefficient way of changing engine oil?
Old 01-24-2010
jrd22's Avatar
Courtney the Dancer
Using the dipstick tube and one of these makes it clean and easy.
Suck-Up Fluid Pump
Also, use two large zip lock bags around your filter when taking it off and you should be able to get it off without spilling a drop.
It's usually difficult to get a container below the level of the oil pan in order to use a hose to drain the oil in most boats, yours might be different.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 01-24-2010
Red
redhead78 is on a distinguished road
Hi people....Kubota Beta has a built in pump hooked up to the drain plug. Built in pump, on the front of the engine They also have an option to install your filter in a more covenient location......Red
Red, 77 Jeanneau Gin Fizz 38
Old 01-24-2010
jjablonowski's Avatar
jjablonowski is on a distinguished road
Yes.
My Universal M-12 diesel is fitted with a drain hose instead of a plug at the bottom of the oil sump. The 12-in. hose has a metal fitting at the end, and the plug fits into that.
The assembly is available as an aftermarket product: Universal 200390 Ships Store Torresen
Old 01-24-2010
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
My old perkins came to me equipped with a drain hose under the oil pan hooked into a small pump. Easy to pump out all the oil from the bottom of the pan.
Old 01-24-2010
Irrationally Exuberant
arf145 is on a distinguished road
I guess it depends on your engine access, but I don't consider using a good pump to be harder or more messing around than draining from a plug--quite the opposite. With a good pump, it's all out and contained with no mess at all.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 01-24-2010
Architeuthis is on a distinguished road
Our old Alberg30 with an Atomic 4 had a plug on the crankcase to which a valve was added and a length of hose attached to make oil drainage easy. It worked well.
Until the valve broke off dumping oil out. Which would not have been so bad but it was while under way and when the boat was in a narrow part of a river, with a tow and barge bearing down, and of course contrary currents. I was not at the helm but apparently as the smoke enveloped the boat the helmsman decided to open the throttle and run it hard aground out of the channel. Didn't lose the boat but what a mess.
I'm not sure adding anything to the crankcase is a good idea.
Have faith that the oceans are going to rise and flood the world, that plague and pestilence brought on by Climate Change is going to punish us for not believing. Please do as they say it is our only hope. :P
Old 01-24-2010
all these confusing ropes
dohenyboy is on a distinguished road
I would never install an engine without a drain hose attached to the sump. Use only the best quality materials.
Last Thursday I changed the oil on two big diesel engines on one of my boats. I have a $120 Shurflo pump mounted on the wall that is permanently connected to the drain hose. Takes 4 minutes to drain 18 quarts of oil.
oil goes into a plastic jerry can I keep just for this purpose. Can do the whole oil and filter change in 15 minutes. No mess.
Old 01-24-2010
JiffyLube's Avatar
Grasshopper
JiffyLube is on a distinguished road
Suck-Up Fluid Pump
I agree with you!
Source for ST60 paddlewheel plug Quickstep192 General Discussion (sailing related) 1 12-31-2009 12:11 PM
Groco SV-756 plug for SV-750 seacock - wish to buy wnor Gear & Maintenance 0 10-27-2009 10:49 AM
Stuck Oil Plug - Ugh Michael K Gear & Maintenance 5 10-03-2009 08:24 PM
Reliability of Kemp furl in systems made in 1990-1991 Grigrigrigoris Gear & Maintenance 0 05-20-2005 02:05 PM
Universal m35 leak at drain plug sailingdeacon Gear & Maintenance 1 01-07-2005 11:21 AM
