Old 01-25-2010
elcap373 is on a distinguished road
Sail in Forward, Reverse, or Neutral?
I have a Hurth ZF 10M transmission on the 24 hp Universal diesel in my Newport 33. The ZF 10M manual indicates the transmission should be in forward or reverse when sailing – not in neutral. I would think it would be advantageous to sail with the prop in neutral to let it free-wheel and reduce drag. Is it truly necessary to operate under sail in with the transmission in forward or reverse?
Old 01-25-2010
jrd22's Avatar
Courtney the Dancer
The prop shaft free wheeling turns the output shaft of the transmission but in most transmissions that does not provide lubrication or cooling which can do a lot of damage.
We put ours in reverse to prevent it from spinning (Volvo).
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 01-25-2010
rocinante33 is on a distinguished road
In neutral, the trans may not lubricate as it should. Since the input shaft is not turning (only the output shaft) the oil in the trans may not circulate to the bearings.
Also, the freewheeling prop is not really less drag than a prop which is stopped. I know it is counterintuitive, but the spinning, freewheeling prop is more drag.
Keith
Rocinante
1983 Ericson 33
Channel Islands, California
Old 01-25-2010
tager's Avatar
tager is on a distinguished road
Counterintuitive.
That is counter to my intuition, can you explain why the spinning prop presents more drag?
Old 01-25-2010
Zanshin's Avatar
Zanshin is on a distinguished road
tager - coming from flying this was also counterintuitive for me. This topic is a popular one and there have been a number of studies done that come to different conclusions. The one that I found to be rigourous in method was in a study done at the University of Strathclyde and can be found in pdf form at http://strathprints.strath.ac.uk/567...ints005670.pdf
Old 01-25-2010
pvanv1's Avatar
Hinterhoeller HR28
pvanv1 is on a distinguished road
The Hurth will not be damaged by sailing in Neutral. One of the few transmissions where that is the case.
Paul Van Voorhees
Certified Tohatsu TLDI Technician
Mgr, Obersheimer Sails
Buffalo, NY USA
Old 01-25-2010
newpbs is on a distinguished road
Be Careful
I'm not sure which Hurth I have but the manual specifically states that the transmission should be in reverse when sailing.
Paul
Old 01-25-2010
nickmerc's Avatar
nickmerc is on a distinguished road
It is correct that a spinning propeller creates more drag than a stationary one. I too fly airplanes and it is very well demonstrated when your engine quites. You will glide significantly further in a fixed pitch propeller airplane if the prop is stopped.
Also, weather the bearings receive lubrication or not, there is no need to turn the shaft when not producing power. It will still wear the bearings needlessly.
________
How To Roll Blunts
Old 01-25-2010
k1vsk will become famous soon enough
I'm not sure boat props follow the same theory as those on airplanes. Being a compressible fluid, the analogy to that of airplane props (in air) falls apart and if you were to substitute the dynamic properties of water vs. air in the equations of the Styrathclyde example, the coefficient of drag changes inversely.
Regardless, this issue has been debated and argued for decades and so-called experts constantly disprove each other. Seems to me you should either get a folding/feathering prop if drag is of great concern or risk the transmission by not following the mfg recommendations. Your choice.
Old 01-25-2010
MSN2Travelers's Avatar
Badger Sailor
MSN2Travelers is on a distinguished road
I crew on a Pearson Flyer and the manual for the boat indicates the transmission should be in reverse too.
Paul
`99 Beneteau Oceanis 352, #282 Witchcraft
Madison/Milwaukee, WI
Sailing Lake Michigan and the Great Lakes
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 02:47 PM
Traveler usage? Humpwalker Seamanship 22 02-17-2007 10:54 AM
The Basics of Reefing Mark Matthews Cruising Articles 0 03-29-2004 07:00 PM
diffrent rigs? (schooner, ketch, cutter, sloop) jbarros Boat Review and Purchase Forum 2 07-09-2003 04:10 PM
First Sail of the Season Bruce Caldwell Learning to Sail Articles 0 06-05-2003 08:00 PM
