01-26-2010
When was the last time the stuffing box was repacked. If you can't tighten the stuffing box lock nut... it might be long overdue.
I'd point out that lower temps means that the shaft will contract in size slightly, and if the flax packing has hardened, it may cause an increased drip rate as the space between the flax and the shaft is slightly larger, due to the metal contracting slightly.
